Tire size CONFUSION - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-20-2010, 03:44 AM
kiddynamite's Avatar
kiddynamite kiddynamite is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: Sport Crew Cab
Rep:35
kiddynamite is on a distinguished road
Default Tire size CONFUSION
I have a 2010 Sport 4x4 and was looking at getting some 305/45/22 tires, but when i took a close look there is less than a half inch between my stock 275/60/20s and the control arm...by the looks of it there is no way in hell i could run a wider tire than stock.
i do NOT want to run spacers or adapters and i'd like to keep the truck at stock height...am i missing something?
Old 11-20-2010, 09:05 AM
Resident Technician
Rep:1915
You'd need to get a wheel with less backspacing and you may even want to go an inch wider.
Old 11-20-2010, 09:46 AM
Rep:35
the rims i was looking at have +25.4 offset...
Old 11-21-2010, 12:32 AM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
you will need to get a rim with 0 offset or a negative offset.
something like 4.50 backspace and -6 or -12 offset
5.00" backspace and 0 offset would work
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-21-2010, 01:24 AM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
I am running 325/60 - 20's and needed a 3/8" spacer because of the control arm. It ONLY rubbed during full lock, othewise it was great as it sat with stock 20" rims. Which would make me believe that the size you wanted would be just fine or even 315's. I was surprised at the flex the tire had near that conrol arm during u-turns, and a little bummed that I had to use a spacer because of it.
2016 3500 Laramie MC 385/900 with Aisin tranny & 4.10 gears: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
