My 97 dodge ram is stuck in first - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 11-20-2010, 10:28 PM
97ram.nick 97ram.nick is offline
Vehicle: 1997 Dodge Ram
97ram.nick is on a distinguished road
Default My 97 dodge ram is stuck in first
hey i recently was driving down the road went to shift from first to second ((its a manual)) and it stays in first.. i can move my shifter from first into second smoothly and it stays in first the whole time including in the neutral position.. i cant move my shift lever what so ever towards 3rd, 4th, 5th or reverse its like theres something blocking it, i really need help and would like to know what might cause this problem and how i can fix it
Old 11-21-2010, 07:37 PM
How many miles do you have on it ? Bearing failure , broken fork etc ... It sounds like it may be time to pull it . Stop by the newbie section and introduce yourself .
Old 11-21-2010, 07:58 PM
Rep:2929
if its a top loader, i would pull the floor panel if it has one, then take off the top transmission plate, you will likely find that the shifter fork is broken or bent
Old 11-21-2010, 11:10 PM
its got 146,xxx on it and there is no way to get into the tranny besides dropping it and opening it up, i know on my cj7 theres a spot on the side i could pop off and check out anything inside that might be wrong but this one doesnt have one
Old 11-21-2010, 11:21 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Before you drop the trans is there a way to check to make sure the shifter isn't broken on the outside?
Brian:
Old 11-21-2010, 11:35 PM
i took the boots off and alittle 4x4 spot to look inside and everything looks fine from the parts that i can see
Old 11-21-2010, 11:55 PM
Rep:2929
if the shifter handle goes directly into the top of the transmission, that is called a top loader
if it goes through the floor & mounts on the transmission & has linkage that connects to the side of the transmission, that is referred to as a side loader
most top loader transmissions have a large access panel in the cabs floor, but, maybe the truck that you have doesn't. The access panel would almost be the size of your
shoe
i am not sure but, you may have a NV4500 transmission, made by New Venture
http://quad4x4.com/Dodge%2094-04%20NV4500.htm here is a good view & more info on it http://www.nv4500.com/
hopefully you don't have a GETRAG transmission http://www.drivetrain.com/parts_cata...ustration.html
NV4500's are great replacement in older trucks with 4 speeds, plus it is also a popular replacement for 5 speed transmissions used in newer trucks. If you happen to have a Dodge 3/4 or 1 ton truck with one of the weak GETRAG transmissions, then the NV4500 transmission is the answer to your problem. . The NV4500 has stronger gears, better case and improved bearings, plus it evens allows you to retain your stock clutch setup!
Old 11-22-2010, 12:08 AM
its the top loader, and when i take everything off the only opening into the top of the transmission is about 4"x4" its very small and i can barely see anything or access anything either and its a NV-3500 transmission
