Old 11-21-2010, 09:59 AM
Xtremebagger Xtremebagger is offline
Vehicle: 1998 ram 2500
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Xtremebagger is on a distinguished road
Default headlights will not shut off
I need some help. I replaced the headlight switch 2 months ago because the headlights would not come on . Now they wontshut off! things I have tried inclued, removing the switch from the wire plug. STILL ON. removing the security relay. STILL ON ! I am woried some wires have melted together. I have 25 years in the collision industry ,ICAR Platium certifcation but I need help with this one.
Old 11-21-2010, 10:38 AM
Rep:1885
You're probably just going to have to start backtracking until you find the short to pwoer that's causing the lights to come on. Is it the headlamps or the DRL's?
Old 11-21-2010, 07:56 PM
Default fixed headlights
I got out the test light and started checking things out and found two wires rubbed together. problem solved and I hope this is the end of it . thanks for the reply!
Old 11-21-2010, 08:34 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 12-13-2010, 08:56 PM
tuc0007 tuc0007 is offline
Vehicle: 97 ram 318
tuc0007 is on a distinguished road
Default head lits stay on
It has to do with the running lights modual disconect this lights should go out
Old 09-17-2012, 05:35 PM
esloan esloan is offline
Vehicle: 2001 Dodge Ram 1500
esloan is on a distinguished road
Default headlight will not go out, and high beam indicator stays on
I have a 2001 Dodge Ram 1500. The headlights will not go out unless you pull the fuses even with the switch off, and even with the switch removed they will stay on if fuses are in, also the highbeam indicator light stays on, even when the headlight switch is removed. can anybody help me with this.
