Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 11-21-2010, 11:38 AM
BHB BHB is offline
BHB is on a distinguished road
Default Have 12v, Nothing when I turn the key...
Hey guys,
I have a 1991 W150 5.2L. Recently I got in, turned the key & nothing happened; no dash lights, no radio lights, seat belt buzzer, no ECU start-up, etc. My first thought was the battery was dead, but upon inspection the battery is fine and all other lights work (headlights, interior lights, etc).
My first thought was the ignition switch was shot, so I replaced that and.... still nothing. No change.
Can anyone help clue me in on what might be wrong? Is there an ignition fuse somewhere that I can't find?
Thanks!
1991 W150 5.2L 4x4
Old 11-21-2010, 11:43 AM
Resident Technician
Rep:1915
I don't have a diagram handy for your truck but you should start checking fuse links, fuses and connections. If you have a test light, this can help you find where you;re losing power.
Old 11-21-2010, 12:15 PM
BHB BHB is offline
All fuse look good (as far as I can tell) and the fuse box has 12v. Everything works except what comes on with the key. So blower motor motor works, hazard lights work, pwr locks work. Radio doesn't, windows don't, etc.
Messed up thing is: I just checked for power at the ignition switch and I have 12v coming into the switch.
Does that mean that the new ignition switch I got is faulty????
1991 W150 5.2L 4x4
Old 11-21-2010, 12:36 PM
Resident Technician
Rep:1915
Check and see what's coming out of the switch and go from there.
Old 11-21-2010, 01:18 PM
BHB BHB is offline
Hmmm...
OK. I tested the new switch for continuity in all key placements. They all check out perfectly according to the book. Ran ground straight from the battery to the switch and still nothing.
So I have power to the switch, the switch tests perfectly, and I have a good ground, and all fuses look good.
Where the sweet hell does that leave me???
1991 W150 5.2L 4x4
Old 11-21-2010, 01:25 PM
Rep:2890
check for power at the starter solenoid would be my guess
Old 11-21-2010, 01:35 PM
Before getting into this too deeply , pull your battery cables loose from your battery and clean them . Even though you have some accessories working you could have a dirty enough connection thats not allowing enough current to flow through .
Old 11-21-2010, 02:08 PM
BHB BHB is offline
Thanks for the input guys.
I'm doubting the starter solenoid because I'm not even getting dash lights. But the headlights work and are very strong.
I misspoke earlier: I do have exactly one wire coming out of the ignition switch working: the one that powers the windows & the blower motor is working. All else (radio/dash lights/ignition) gets me nothing in any key position. All fuses for the non-working items are good.
I'f flummoxed...
1991 W150 5.2L 4x4
Old 11-21-2010, 06:20 PM
You should have several fusible links by the starter relay . They look like regular pieces of wire that burn . They may be marked . Pull on the wire itself and see if they pull apart .
Old 11-22-2010, 01:44 PM
BHB BHB is offline
Fixed.
All the fusible links were good, but I noticed that they all came back together into one wire that went directly to the + size of the battery. That wire had a single connector in it right next to that, when pulled apart, turned out to be really corroded. Cleaned that up and she started right up.
My only guess as to what was happening is that I was getting 12v @ the ignition switch, but it somehow wasn't enough (or enough amps) or something to jump the relays when the switch was turned to power anything...
1991 W150 5.2L 4x4
