Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 11-21-2010, 02:17 PM
sammyd sammyd is offline
Vehicle: 1993 Dodge d350
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
sammyd is on a distinguished road
Default odometer quits & transmission quits
When it is wet or after a wash down my Dodge d350,1993, has autotransmission shifting problems. The odometer also quiits. When it dries off or sometimes by stopping and re starting it, it sometimes solves the problem. Im sure it is a electrical relay/sender, but is it the one on the trany or elsewhere?
Old 11-21-2010, 06:30 PM
What are you washing ? Just the outside of the truck or under the hood also .
Old 11-21-2010, 10:38 PM
Just the outside. Thank You for your interest.
Old 11-30-2010, 09:01 PM
Problem solved with the replacement of the vehicle speed sensor. Working great now. Thanks
Old 11-30-2010, 10:01 PM
Thats interesting . Did you hose off the bottom side of the truck ?
Old 12-03-2010, 09:13 AM
No bottom hoseing but when I checked the speed sensor I discovered the O ring was leaking and allowing fluid to enter the electric plug. My guess is that the combo of water and oil shorted the system as it did when it rained also. But a new sensor saved the day. Thanks for your interest.
