my hemi has problems!!!!!! please help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 11-21-2010, 07:38 PM
jethead7200 jethead7200 is offline
Vehicle: 2004 dodge ram 1500 hemi
Trim Level: 2wd st
Color: gray
jethead7200 is on a distinguished road
Default my hemi has problems!!!!!! please help
hello everyone,
ill start off by saying i have a 2004 dodge ram 1500 5.7 hemi, about a month ago i noticed that my truck was having problems making power, but only when it was cold, i would drive about 30 mph and push the gas down and it would bogg down and not go any faster, when it warmed up no problems, well this lasted a week and then it would get worse, at stop signs/lights it would fluctuate the RPM's and die, but always start right back up but it would hesitate from a stop when i push the gas down, i have some what of an extensive backround with cars, knowing this i cleaned the throttle body (witch had some oil in it) PCV valve, and even changed the EGR valve, reset the comp, ran perfect for 2 days and the problem came back, my next thought was the MAP sensor, any suggestions woulb be great, i just dont know why after resetting the comp everytime it would run perfect, but only for a day or so of short trips, oh yea by the way i have never gotten a CEL with any of this!!!!!!
Old 11-21-2010, 08:12 PM
Have you verified that by checking for codes anyway . It could be a fuel pressure issue .
Old 11-21-2010, 08:20 PM
Rep:2962
it may be that you need to replace the plenum gasket, also called the intake manifold gasket
Hopefully someone will help you better than i can
if you see oil or water sitting on top of your engine, that is a symptom
Intake manifold leak symptoms
Intake manifold leak symptoms are pretty obvious. If there is a leak in the coolant passages, water or steam will leak out and should be visible either when the engine is idling, or with a puddle that forms when the engine is parked. Take a look underneath when you park the car if in doubt. Other intake manifold leak symptoms include a lowering of the water level in the top tank. If that keeps falling you have a leak somewhere. At least a leak in the manifold is better than a leak in the cylinder head much cheaper to replace.
You can use a vacuum gauge to check the manifold pressure, but an easier way of finding a leak is to get a small propane gas cylinder from a hardware store, and get the engine running. Then you squirt a little gas along the edge of the manifold joint. When you find the leak, the gas will go in through it, and the engine speed will rise, and then be smoother. Now you know where the leak is. Then, you will need to remove the manifold, first draining the coolant system, to correct the problem.
Old 11-21-2010, 09:25 PM
Trim Level: 2wd st
Color: gray
thanks man thats alot of good info that gasket had crossed my mind but the truck only has 55000 miles on it so i didnt think it could b bad, i also noticed some water comming from the tail pipe as well, and the coolant level is low also, what about the fact that resetting my comp makes it run perfect durning the relearning process.
Old 11-21-2010, 09:28 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 12-06-2010, 06:18 PM
M109R M109R is offline
Vehicle: 2006 Ram 1500 Big Horn----
Color: Pearl White
Rep:28
M109R is on a distinguished road
I'm not at all saying my issue was EXACTLY the same, but I too was having issues getting my truck to move and it too would die at stop signs. My issue...again...MY issue was my trans. filter and fluid. I have a 2006 Ram that I bought with 39,000miles and now have 65,000 when I had the issue. Changed my trans. filter and fluid....issue fixed. There again, that was MY issue. Good Luck!
2006 White QC Big Horn- Hemi
2000 Maroon Ext. cab- 360
Old 12-06-2010, 06:33 PM
Rep:2962
Jethead7200,
Water out of your tailpipe may not have anything to do with your problem
in a good running vehicle, your catalytic converter will put out water drops, sometimes as much as what seems to be 1/4 cup of water
this is what happens
Hot exhaust gases exit your engine and head through your exhaust to the catalytic converter. Inside this expanded tube is a massive network or honeycomb of ceramics. This ceramic checkpoint has been coated with compounds that react with the exhaust to eliminate certain harmful emissions. Even though the exhaust is flying through the tube at high velocity, the molecules that coat the ceramics are able to react in milliseconds, hanging on to the bad stuff until it's converted to something harmless (or less harmful) like Nitrogen, Carbon Dioxide or water vapor.
