Old 11-21-2010, 07:19 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
Default wheel spacers
Can somebody help me i wanta put 2 inch wheel spacers on the front of my 2wd ram so i can put fiberglass fenders are 2 inch wheel spacers bad on the truck? Its my DD and rarely sees dirt and i know i cant offroad with it with wheel spacers because the added leverage but being street differnce do i need to worry still?
Old 11-21-2010, 08:49 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
2" thats alot of spacer,i would think that might be alittle unsafe!
im sure someone else will give their opinion on this!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-21-2010, 08:52 PM
cosbourn's Avatar
cosbourn cosbourn is offline
Vehicle: 2004 Dodge Ram QC 4x4
Rep:83
cosbourn will become famous soon enough
i would persuade to NOT do that. haha. 2"'s in spacer world is huge! think about the stress you put the bearings under when you have that much of a "springboard" hanging out from them. I would look into some different backspaced wheels instead of that route because it will come back to haunt you later on. trust me, it did to me when i leveled my last 2wd. bearing literally exploded in the hub, catastrophic failure, and a destroyed spindle. not fun..
Westin Ultimate Bull Bar w/ IPF 968CSG lights, Husky Mud Flaps, Bedlined GoRhino Dominator II steps, Bedlined Fuel Door, RBP Pedal-Covers, Clarion CZ300, Composite BFI (#71) w/ 8" Tall Amsoil Filter + K&N Drycharger Prefilter, AirRam Scoop, Flex-a-Lite 183, dumped Aeroturbine 3030XL
Old 11-21-2010, 10:38 PM
I push the skinny pedal
Rep:3283
My boss has 1.75" spacers on his long-base Jeep, but he is VERY picky about how they are installed. You HAVE to get dual bolt spacers at that size, and I'd be very hesitant to do it on a truck, since it has about another 1-2000 lbs on the jeep. Yes it can be done, but for safety reasons I wouldn't recommend it.
Kurtis
Old 11-21-2010, 10:43 PM
cosbourn's Avatar
Rep:83
x2
jeeps can get away with it because of weight difference. trucks, not so much. haha.
Old 11-22-2010, 02:55 AM
Rep:53
Thats what i was thinking and i was looking at the ones that are more of an adapter with seperate wheel lugs. Ive seen it on chevys its a street queen till i get the suspension done, and when the suspension is done the wheel spacers are gone. Its just to get the front end wider so i can fill 4 inch bulge fenders. And a different offset would do the same tho wouldnt it? its still pushing the wheel out which adds leverage? And i couldnt do that because i want the front wider then the rear.
And i agree it seems really sketchy to me but ive seen it done on a couple other trucks rangers and silvys.
Old 11-22-2010, 03:07 AM
Rep:53
this guy has 4 inch lift up front with 2 inch spacers and 4 inch fiberglass and in the rear a 2 inch drop with pulled bedsides and hes running 35s.
i want to do my ram like this but leave my 7 upfront an my stock height rear.
Old 11-22-2010, 03:27 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Quick lesson on spacers.
Sandwhich style spacers (the ones you use almost a shim) are unsafe and should be illegal.
Bolt on spacers, such as those by quality manufacturers (Ballistic Fab, TeraFlex, SpiderTrax, etc) are generally a very safe product. The amount of leverage they apply to your unit bearing is no different that having a wheel with the same backspace. If installed properly and maintained (check the torque on the nuts regularly, usually when rotating tires) they can be very safe.
For the Jeep comment above. Yes Jeeps USED to be much lighter than fullsize trucks. Todays JKs are alot heavier than they look. My 2dr on 35's weighs in at just a hair over 5k wet. A friend of mine has for door on 38.50"s and loaded for the trail comes in at well over 8k, and he has been running 1.5" spacers for over 50k miles. I doubt many of you have your vehicles north of 8,000lbs.
If you want to run 2" spacers I say go for it. Just dont cheap out. Get a quality unit, and talk to the manufacturer. Most will be very straight with you about their product and what it can and cant do. I have personal experience with SpiderTrax and highly recomended them.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 11-22-2010, 03:40 PM
Rep:53
yea the shim ones are just flat out stupid. Iwas planning on using the bolt on spacers if i did do this. Is there a name for these because seems like if i say spacer everyone thinks of the shim would it be a adaptor style spacer? I found a couple places that can get them it seems like they range from 90 to 150 bucks.
Thanks for the reply
Old 11-22-2010, 04:17 PM
Rep:256
Not completley sure of the rules but here are a few websites.
www.spidertrax.com
www.balisticfabrication.com
www.teraflex.biz
They all compete with eachother and they all make great products so I dont think it is wrong posting the info.
