Old 11-21-2010, 09:51 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Default Lets talk sludge
Dodge trucks are notorious for sludging, and I have seen it first hand in my own 4.7. I have seen the goo piled up on my oil cap and know that it can fill oiling ports and lead to an early demise for the motor. What can I do in my truck to fight what it currently has and prevent it in the future. Any products or recommendations?
My truck has an obvious audible tick (like a lifter) until it warms up. My guess is once the engine heats up enough the oil get to this area and silences it. Before I experience a problem, what do you guys know that works?
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 11-21-2010, 11:40 PM
I push the skinny pedal
Rep:3277
a centrifugal oil filter and a synthetic oil would go a long way, but the most helpful would be a regular cleaning of the oil pan, there's no real 'fix' that I've heard of.
Kurtis
Old 11-22-2010, 10:01 AM
Rep:1877
What you see in the inside of your cap isn't always a good indicator of what the inside of the engine looks like. Mine looks pretty rough from time to time but I know the internals are clean. If you want to get a good idea of what's going on in your engine, pull a valve cover.
Old 11-22-2010, 10:27 AM
A good way of fighting a sludging problem is more frequent oil changes and/or running a good quality synthetic oil like Amsoil .
Old 11-23-2010, 05:46 PM
OldMoparMan63's Avatar
OldMoparMan63 OldMoparMan63 is offline
Vehicle: 2002 Ram 1500 QC-4.7
Color: DK Blue
Rep:68
OldMoparMan63 will become famous soon enough
Excellent point.
The oil fill spout is elevated and is plastic. Plastic does not transfer heat.
What you're seeing is oil vapors that rise in that tube, and are exposed to cooler air, causing condensation, hence the tan, gooie, build up you get.
Short trips where the engine doesn't reach full operating temps long enough to dry it out, will make it worse. Not to mention, the PCV valve is there, sucking engine/oil vapor up to that location.
Ford had the same issue on the older small block engines, at the oil fill cap, where the PCV fit into.
It's harmless.....just really annoying to see, and you'll see it more in the winter/coller months then you will in the summer, because of the warmer, summer ambient temps.
Old 11-26-2010, 03:20 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
frequent oil changes and that brand in the same sentence - thats a first
the best way to avoid sludge issues is to follow the mopar maintenance schedule to a tee using fluids with the correct recommended certifications.
following mopar's recommendations, we've had four late model mopars, all with over 100k on the odometer and not one issue...
Old 11-26-2010, 01:24 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
that is not true.....only engine weve had that was prone to sludge if regular maint was not followed to the T was the 2.7.....
in any engine if you do not change the oil as recommended you are asking for trouble....
Originally Posted by OldMoparMan63 View Post
Excellent point.
^^^true story^^^
amsoil is not a recommended lubricant by any manufacturer that i know of
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 11-26-2010, 01:33 PM
Rep:1877
Perhaps not but it does meet the ILSAC GF-4 and the Chrysler MS-6395N standards and is safe to use. Royal Purple does not meet these standards the last time I checked.
Old 11-26-2010, 01:59 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
no your right.....i would not use royal purple either.....i use mobil 1
never been a fan of snake oil!
Old 11-26-2010, 02:14 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
I used Royal Purple for 2 years with no problems, but I now run Mobil 1 full Synthetic 15KM Extended Protection just to be on the safe side.
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
