Old 11-26-2010, 05:43 PM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
Originally Posted by sprintertech View Post
amsoil is not a recommended lubricant by any manufacturer that i know of
no api cert either...
but, if you're looking for a once in a lifetime business opportunity...
Old 11-26-2010, 05:53 PM
Rep:1877
no your right.....i would not use royal purple either.....i use mobil 1
I also use M1 synthetic and the inside of my 3.7 is sludge free at 90k miles. I change it at every 5k along with the filter. Right now, I'm trying out the extended life formula that claims 15k between changes but I plan to change it at 10k. Around 5k, I'll pull a valve cover and check for any signs of trouble.
Old 11-26-2010, 09:54 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
This is very interesting.
I just purchased my ram a couple months ago. I immediately took notice of the yellow goo in the oil filler tube of my 4.7. I watched it run with the oil filler cap off, lots of condensation there and when I clean the oil filler tube it only takes 50 miles or so to build right back up. I had assumed I had a small head gasket leak, or maybe even a crack somewhere. I have never noticed any real steam in the exhaust or any drop in the coolant level.
Are you guys saying this yellow buildup is normal for this engine? Not an internal leak, while I find this surprising, I would be pleased to know its not a crack or leak.
If this is normal, are you saying that good synthetic oils are better at reducing this occurrence?
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 11-26-2010, 10:15 PM
Trim Level: sxt
Rep:197
it is normal - your 2003 might fall under the kit chrysler made to remedy this by re-routing the pcv hose/assembly. both my dad's 04 and my 05 do this from time to time.
Old 11-26-2010, 10:22 PM
Color: Gold/Silver
Very interesting. Where can I find more data on that?
Old 11-26-2010, 11:09 PM
Color: Gold/Silver
Did some looking. Found this Dodge bulletin:
TSB 25-001-06
here's a link:http://dodgeram.info/tsb/2006/25-001-06.htm
Old 11-26-2010, 11:39 PM
05qc 05qc is offline
Vehicle: 2005 Dodge Ram quad cab 1500
05qc is on a distinguished road
another vote for synthetic.
sorry if i missed it, but what kind of oil are you putting in your truck?
Old 11-26-2010, 11:45 PM
Color: Gold/Silver
I've changed it twice since I got it, two months, and both times I used Quaker State Premium 5w-30.
I think tomorrow I'm going to get some Mobil 1 or other high quality full synthetic.
Old 11-27-2010, 12:17 AM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
SO the sound of a lifter tap until my truck warns up, is this normal, or is it as I thought and is sludge/heat related? I always use conventional oil in this vehicle, 5k oil changes w/ castrol high mileage.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
if mercedes likes it i like it.....but really.......had 120k on my last 4.7 without a single problem.....always ran mobil 1.....went over 10k miles on occasion....
my honest opinion is you could buy the cheapest oil on the market in the correct weight for your engine and change the oil every 3k and be fine.....
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
