Old 11-22-2010, 06:24 PM
Talayoe's Avatar
Talayoe Talayoe is offline
Color: Blue
Talayoe is on a distinguished road
Default Dual Climate Control - Delay?
I get this alot in the mornings (which really sux! right now since it's about -30c here). I remote start the truck for about 5 - 10 min before I get in, when I put the key in and turn on the system it gives me the temp on the dual display and says 'Delay' under it.
While in the delay the fans do not respond and run at a very LOW (like setting 1) blow. This is ONLY on the AUTO setting tho. If I put it to setting 1 it works fine (or any of the others). But I like the Auto.
How do I get rid of this...?
Old 11-23-2010, 09:52 AM
Talayoe's Avatar
Color: Blue
Nobody else seen this?
Old 11-25-2010, 03:06 PM
dgard61's Avatar
dgard61 dgard61 is offline
Vehicle: 2010 Ram Crew Cab, 4x4 Laramie
Color: Inferno Red/Sandstone
Rep:91
dgard61 will become famous soon enough
Pretty sure you can't. When the heater controls are in auto the fan's speed doesn't increase till the coolant reaches a certain temperature. I would imagine it's to keep from blowing cold air into the cab. Plus at -30C it's going to take awhile to warm that sucker up.
Vent Visor's, Bug Deflector, Chrome Fuel Door, Bak Flip G2 Tonneau Cover, Bed Extender, EZ Down Tailgate Dampener, Line X Spray in Box Liner, WeatherTech Winter Mats, Husky Moulded Mud Flaps, Billet Tech Oil Catch Can, 12" S/S Antenna Mast, Chrome T/G Handle, Mopar CAI, Painted Engine Cover, Billet Tech Polished Underhood Cap's, Front Window Tint, Billet Hitch Cover, Anti-Theft Valve Cap's, MGP Caliper Covers, Retractable S/S Stake Pocket Anchors, Mopar Trailer Brake Controller, Recon LED Light Bar, Polished Billet Lock Pins, Mopar S/S Door Sills, Interior LED's, Mopar LED Cargo Bed Lights, Billet Throttle Body Cover
Old 11-25-2010, 03:46 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Plus the engine will heat up faster without the fan on/blowing cold air. If you really need the fan you'll have to turn the fan speed up manually. did you notice that the fan blows fast with the remote start until you turn the key fob o "on"?
Old 11-25-2010, 04:24 PM
Rep:2705
it took me a while to figure out the Rams climate control settings
no one but me rides in the Ram 99% of the time
i keep the 2 vents closed on the passenger side & the drivers side vents are set to my liking
If the weather is going to be cold in the mornings, i set the fan to 1/3 - 1/2 way on, circulation off, i set the temperature at 75 degrees & i keep the vent setting on AUTOmatic, i make these settings when i park the night before, & in the morning i use my remote start & i finish getting ready to go out & the Ram is ready to to go, blowing heat, before i turn the key
I found that if you don't set the fan & temperature & leave it on AUTO, the fan doesn't start blowing UNTIL you get in & turn the key, even though the engine has been running for several minutes.
when its going to be hot in the morning, i set the temp to 67 degrees, fan to desired setting, ( anything BUT AUTO ), & circulation on, vents on Auto again.
This method has been working well for me, setting the vents to AUTO allows it to make the choice of using the defroster when needed
Old 12-04-2010, 03:06 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
I am not an expert but this is what I think...
Remote start had an option in your setting for convenience or something similar. When activated if the temp is under a certain temp your seat/steering wheel heater are activated and the fan blows on high. The delay is only during the auto function. It will keep your fan from blowing until the engine begins to warm up...
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 12-04-2010, 08:27 AM
Weeser's Avatar
Weeser Weeser is offline
Vehicle: 2010 ram 1500 4x4 quadcab
Trim Level: sport
Color: deep water blue
Weeser is on a distinguished road
I got a recall notice invoving this...they have to reprogram HVAC control head and inspect the actuator.....recall K17
Old 12-04-2010, 09:49 AM
Resident Technician
Rep:1909
This has nothing to do with the issue at hand but rather a problem with the defrost actuator.
Old 12-04-2010, 12:32 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
With the climate control in the 'auto' position, during remote start mine runs the blower at a high speed in defrost mode and activates the heated seat (drivers side) and heated steering. When the key is inserted, it will change the vent setting to whatever I have selected on the dial, and will either run the blower to until the set cabin temp is achieved, or run the blower on the lowest setting with 'delay' showing in the display until the engine temp is high enough to add usable heat to the cabin.
I often see the 'delay', as I don't normally let the truck run long after remote starting. Usually I have heat within 1 minute of driving.
brad
Interested in one of my mods?
Old 02-24-2011, 06:47 PM
Talayoe's Avatar
Color: Blue
Sorry to reply to this 2 months (almost 3!) late(r). Went to Hawaii right after I posted it and totally forgot. Amazing when you are searching for your own issue. lol!
Brad12kx seems have nailed it on the head. Mine does the exact same thing. Blower on MAX when the remote start has been activated (climate controls in Auto) and then dies down when the key is in and kicks back up a few minutes into the drive.
How it was worded totally makes sense to me. Tks for all the replies!
