Old 11-24-2010, 08:57 AM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
the rear vents blow when the knob is set to the center vents. problem is there r 4 center vents on the dash then those vents way in the back. if u close some of the center vents airflow should increase in the rear.
Too many mods to fit here!
Old 11-24-2010, 11:54 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
so you have an option of either heat in the front or heat in the back, but not both....interesting choice.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 11-24-2010, 11:12 PM
HEMILANCER's Avatar
Rep:85
ahh but if you have heated seats and steering you can have the best of both worlds
Old 11-25-2010, 12:46 AM
steve57's Avatar
steve57 steve57 is offline
Trim Level: ST quad cab 4wd
steve57 is on a distinguished road
I don't have the console on my 2010 Ram, but I notice very little airflow from the
console vents in my 2011 Taurus. Most airflow comes from under the seat, so
I would say it is normal.
Old 11-25-2010, 12:32 PM
Lirver Lirver is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Lirver is on a distinguished road
I was just playing with the dash vents. Closing them does increase air flow to the rear.
Old 11-26-2010, 12:19 PM
latitud's Avatar
Rep:71
Sounds like there would be a nice market for a modification of some sort that would put a fan into the vent to increase airflow..time to put on the engineering cap!
Old 11-26-2010, 02:55 PM
NewMexicoRam NewMexicoRam is offline
Vehicle: 2010 Dodge Ram 1500 4WD
Color: Gray
NewMexicoRam is on a distinguished road
Hemilancer is right. If you close the 2 center dash vents the airflow increases to the rear vents...Not much but it does make a difference. Drove my sister-in-law to the airport this morning and adjusted my vents as described and we were all very comfortable. It was 16 degrees this morning.
Old 11-26-2010, 09:29 PM
HEMILANCER's Avatar
Rep:85
if u could put a fan somewhere under the center console in the ducting it would assist the blower in getting the air out the rear vents
Old 01-18-2011, 12:06 PM
mrsprinkler mrsprinkler is offline
Vehicle: 2010 Dodge Ram 2500 Crew Cab
Color: Grey
mrsprinkler is on a distinguished road
I had the same thing. I pulled the console and installed a small blower/fan right at the vent. Only problem with it is it's one speed so it blows the same amount of air no matter what. If someone is back there and gets too hot or cold they just close/open the vents in the console. Wish it had a factory set up thats for sure.
Old 01-18-2011, 09:26 PM
ABD26's Avatar
ABD26 ABD26 is offline
Vehicle: 2010 Dodge Ram 5.7 Crew 4X4
Rep:176
ABD26 has a spectacular aura aboutABD26 has a spectacular aura about
I noticed the weak flow. I had the recall addressed on Friday. I am sorry to report that after the recall HVAC issue was taken care of, there was still no change in the air flow. I imagine it's an engineering defect that we will all have to live with.
"A two-year-old is kind of like having a blender, but you don't have a top for it."- J. Seinfeld
