Check Engine light - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 11-23-2010, 02:24 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
Default Check Engine light
I bought my truck in August 2009 new. When winter came & temp's got down to the -20s my Check Engine light started to come on. The truck is Plugged in when not in use so all is nice & warm. Someone told me to put her in the garage for a while & this cured the problem. This year the same thing is happening. Anyone got any ideas why this could happen ??? All gauges are showing good & no trouble code's showing.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 11-23-2010, 03:13 PM
If your check engine light has come on , it should of stored a code . Just because the lights out doesn't mean there's no code . Get it scanned and let us know what the code is .
Old 11-23-2010, 03:20 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
Thank's Tom, can i do it with the Predator or do i have to take it in.
Old 11-23-2010, 03:35 PM
I believe the predator has the ability to (most tuners do) access trouble codes . I'm not 100% sure because I have my own scanner .
Old 11-23-2010, 03:44 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
Hey Hey Hey Tom,just plugged the tuner in & it came up with PO300 Random Misfire. Cleared it & light has gone out. Truck is going in for HVAC Reacall on Friday so i will try & find out why it came up in the first place. Thank's for the help.
Old 11-23-2010, 03:52 PM
Before you take it in , put the stock tune back on the truck . Don't tell them you had a tune on it . Tell them , someone checked and cleared the code for ya and that it was trouble code PO300 . Let us know how you make out .
Old 11-23-2010, 03:57 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
I sure will Tom. Thank's again man. I'm thinking of putting the stock tune back on for the winter anyway. It might make life a little easier in the snow & ice.
Old 11-23-2010, 03:58 PM
Good luck and keep us posted
Old 11-23-2010, 05:02 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Yes, let us know what you find out.
I had a Chrysler 300M that used to throw misfire codes whenever the cam sensor was on the way out. I went through cam sensors like I changed underwear (well, not really) with that vehicle, and am hoping the 5.7 doesn't have the same appetite for those sensors.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2017 Dodge Durango GT
2012 Jeep Grand Cherokee Limited (SOLD)
Old 11-26-2010, 09:06 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
Truck went in today for HVAC Recall so i told them about the Missfire code but he said i should have not cleared it as they can't tell which Sensor caused it to pop up. Told me if it happen's again to just call in & they will take a look..........
