Old 11-25-2010, 05:36 PM
pieece's Avatar
pieece pieece is offline
Vehicle: 03 Dodge Ram 1500 QC 4X4 5.7H
Color: Two Tone - Grey/Silver
Rep:38
pieece is on a distinguished road
Default Easiest way to remove pin stripes?
What is the easiest way to remove pin stripes. Mine are definitely faded to the point where they need to be changed.
Any pointers?
17" Eagle Rims/2" Leveling Kit/33" Nitto Terra Grapplers/Billet Grille/K&N CAI/SUPERCHIP/-5% Tint/Black Chrome Running Boards/Black Chrome Light Bar/Behind the Grille Running lights - HALOS/4 100W KC Daylighters - Black/Fire-Ice Bar/Recon Smoked LED Cab Lights/Electronic Safe/
Old 11-25-2010, 05:40 PM
Try a little 3M adhesive remover to break down tape adhesive (I assume this is tape, right?) then pull lightly to remove, then go back over the left over with a bit more adhesive remover. You might need to use an eraser wheel for the tougher bits.
Gonna do some new ones?
Old 11-25-2010, 05:45 PM
pieece's Avatar
Rep:38
Yes they are tape. As far as pulling and peeling them all off at once well thats a different story. I'm going to be there for awhile. I will give it a try of what you recommended.
And i'm going to add more pin stripes. No idea what color yet though. I might also go them painted on instead of the tape, that way I do not run into this problem again.
Old 11-25-2010, 05:47 PM
Yeah...painting will def be a better way to go.
Old 11-25-2010, 07:49 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
There is also an eraser wheel that goes on your drill. Check your auto parts store.
Brian:
Old 11-25-2010, 07:54 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2836
you can also use a heat gun or a hair dryer at a low setting, just don't stand on a wet surface, no reason to play with electricity
Old 11-25-2010, 08:39 PM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
Get an extension cord, hair dyer, heat it up and just pick at it with your nails. Once it is off, use some wax or compound to clean up the area.
Mike
'04 Ram
"Yea its got a hemi!"
Old 11-29-2010, 05:48 PM
Infernogrl6's Avatar
Infernogrl6 Infernogrl6 is offline
Vehicle: 06 Dodge Ram Hemi!
Color: Inferno Red
Infernogrl6 is on a distinguished road
I had this problem as well with my body spears. I baked the truck in the sun for awhile then used a hair dryer then once I got some part up, I used some fishing line and slowly slid it underneath and began to slowly moving the fishing line peeling the spears away.
Then I just used bug/tar remover to remove the excess 3m tape that was left over.
I would wait for a nice sunny day to do this so at least the sun might help a bit even if it's a bit cold out.
Old 11-29-2010, 06:17 PM
ccga3359 ccga3359 is offline
Vehicle: 2005 Dodge Ram 1500
Color: Atlantic Blue
Rep:42
ccga3359 is on a distinguished road
I'm surprised no one suggested a grinder! Quickest and easiest way. Hair dryer and goo-be-gone is slower but safer. I used dental floss to debadge my car.
Grant
No matter how much you push the envelope, it's still stationary.
Old 12-05-2010, 10:46 AM
IntenseBlue98 IntenseBlue98 is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: Sport Club Cab
Rep:13
IntenseBlue98 is on a distinguished road
i was using a 1400 psi power washer and accidentally took part of my pin stripes off. Use a turbo head and whoooosh it right off!
