Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 11-25-2010, 04:39 PM
ICEMAN99TURBO's Avatar
ICEMAN99TURBO ICEMAN99TURBO is offline
Vehicle: 08 Ram
Trim Level: 1500 Big Horn
Color: Electric Blue Pearl
Rep:119
ICEMAN99TURBO will become famous soon enoughICEMAN99TURBO will become famous soon enough
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
Default How To: Front LED Turn Signal Install
I figured there were a few threads on what they look like, but none on how to.. So here is a few pics I took to make it a bit easier for those of you who would like to do this but are unsure; hope it helps.
This is how I did it, not sure if you want to follow 100%, but this is the best and cleanest way I know to do it right.
Things you will need...
- 2: Amber 3157 LED bulbs (SuperBrightLED.com)
- 2: RL-650 Tail Light Load Resistor kit (SuperBrightLED.com)
- Electrical Tape
- White Grease / Anti Seize
- Wire Strippers
- Wire Nippers
- Terminal Connectors (2 Male / 2 Female)
- Wire Connector Crimps
- Flat Head Screw Driver
- Clean Towel or Rag
- 10 mm Socket
- Socket Driver
- Socket Extension
Start off by opening the hood to remove the headlights... Notice the 10mm nut/Torx heads at the front of the light...Remove them and put them in a safe place.
Go to where the bumper meets the fender, there is a hidden nut under there holding the back of the light... Remove it and put it with the others.
There it is... The drivers side has a nice rubber cover to access it. The passanger side on the other hand. You have to use your socket and the extension to get that one off; got to love Chrysler products.
Take your flat head screw driver and your rag or towel and gently pry the back of the light, she will pop right out.
Unplug the connectors and set the light aside... It is time for a little wire modding.
Being that the LEDs are for the blinkers you need to wire of load resistors. The resistors drop the load so that the LEDs are able to follow the blinker signal, other than that the power will be too much and the LEDs will see it as constant power and will just stay solid. You NEED these to make them blink!
After you pulled back the wire loom you will notice 3 wires, the Constant, the Blinker, and Ground. Locate the Black and the White/Green (Drivers Side) and the White/tan (Passenger Side). These are the 2 wires you will be attaching your load resistors to.
Take your wire strippers and just strip about 3/16" of coating off, so you can solder your leads on.. Do Not Cut, just strip.
Next comes the leads..... I'm using the leads (about 3" of wire Black and Red) with connectors so if I ever decide I don't want to use LEDs anymore, I can easily remove the load resistors without damaging the OEM harness.
After all soldered, tape them up with some good electrical tape so the connections are not going to accidentally touch. After everything is taped up nice, push the wires back into the wire loom...That part is done.
Don't park in the ditch, that's not where you park, you park in a parking lot! .... Stupid!
Old 11-25-2010, 04:42 PM
Vehicle: 08 Ram
Rep:119
Load resistors and bulb time! Pretty!
Use your connectors and crimp 1 male and 1 female on each end of the load resistor and the leads that you soldered on. I jump them as to not mess up the connections.
**IMPORTANT**
The load resistor doesn't have a right or wrong way to connect it, just make sure one wire is to the Blinker (White/Green or White/Tan) wire, and one is on the Ground (Black).
Test run, the bulb works, blinks, and running. After your test run, make sure you stick the load resistor somewhere that will keep it protected and so it will not damage anything plastic or painted. I tie strapped it to the radiator support to keep this very thought.
After all is well, reverse the steps and install the connectors and the headlight. Follow the same directions for the passenger side, just keep in mind that the blinker wire for that is White/Tan. Hope this helped everyone and hope you enjoy this mod.
Old 11-25-2010, 04:43 PM
MADDOG MADDOG is offline
Rep:22
Very nice write up.
Moving this to the Knowledge Base.
Old 11-25-2010, 04:48 PM
Vehicle: 08 Ram
Rep:119
Very nice write up.
Sounds good man, and thank you... I was kind of unsure where to put it since I was kind of looking for like a "Garage" section and was unable to find it.
Old 11-25-2010, 04:50 PM
Rep:22
We use the Knowledge Base when someone does a nice job, as you did here, with a How To whether it be mods, general maintenance, repairs, whatever...
Old 11-25-2010, 07:19 PM
loudrango's Avatar
loudrango loudrango is offline
Vehicle: 97 Ram,96 Ram,98 rango,01 rang
Trim Level: ram slt -rango r/t
Rep:64
loudrango will become famous soon enough
great write up.
2005 IASCA Stock 3 World Champion
2004 IASCA World Finals 4th place
Old 11-25-2010, 07:42 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
An excellent post, thanks for the effort on putting this up.
Old 11-26-2010, 07:06 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
very nice!!
Old 11-26-2010, 07:44 PM
I push the skinny pedal
Rep:3277
Great write up, I've done this myself and I did the exact same thing, even down to the soldering (it's optional).
Kurtis
Old 11-28-2010, 02:24 PM
Vehicle: 08 Ram
Rep:119
Personally I see no other way to do it. Rep for going that extra step.
