Old 11-25-2010, 11:45 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Default Painting Plastics
Within the next week I will be ordering the airriad intake tube for my truck. (in my research of everyones opinions and my own Ive come the conclusion that the stock air hat/tubing is what gives bad airflow. The replacement "cai" aka ram air cone isnt really doing much w/o a proper cold air damn that would just suck when off road) any way I want to paint mine red put a nice mopar M sticker on it then clear coat over it. I have zero expericience painting plastics. Should I just sand down paint w/ paint meant for high heat put on sticker then clear coat anyone got any suggestions?
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 11-26-2010, 12:43 AM
dodgemannc2008's Avatar
dodgemannc2008 dodgemannc2008 is offline
Vehicle: 2006 dodge ram 1500 4x4 4.7LV8
dodgemannc2008 is on a distinguished road
hey man from personal experience painting plastics you have to be careful how you sand it cause it can really show through all the imperfections or areas where to have dug in..... i would lightly sand it just get if cleaned and rough it up use a high grade primer two coats then use i guess a high heat paint would be a good idea but sometimes they come out very textured..... either way give it a good 3 coats of that and atleast 2 good coats of clear coat and i think you will be good.
Old 11-26-2010, 07:33 AM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
I've had great luck with Krylon Fusion rattle can paint for under hood work I've done. I've done the engine cover, the fan shroud and, before I put my CAI on, the air intake box top and duct. No problem with heat bubbling the paint, etc. I could smell the paint "baking" the first time I drove it after painting but no damage and the slight smell went away in a day or so. I didn't sand at all but I did do a good toluene wipe down before starting. Now, saying all of that I have not gone back with a clear coat (I don't know if Krylon makes a clear coat in Fusion) so I can't offer any suggestions other than it would make for a smoother, more finished look. Mine is a very basic Mopar blue and white scheme but if you dig around the Z some there are some really nice homemade paint jobs to check out.
Good luck and let us see the finished results.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 11-26-2010, 09:06 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I have used adhesion promoter, then just regular spray bomb stuff and I can then get the body match stuff.
I have heard good things about the Fusion stuff.
Old 11-27-2010, 11:30 AM
FRCEFED's Avatar
FRCEFED FRCEFED is offline
Vehicle: 2014 Dodge Ram
Trim Level: 1500 sport
Color: Black!
FRCEFED is on a distinguished road
^^ +1
I have duplicolor adhesion promoter and it works great!
