Old 11-27-2010, 10:39 PM
GRam's Avatar
GRam GRam is offline
Vehicle: 2011 Ram
GRam is on a distinguished road
Yyyyyup I was swearing those exact smae words when I was changing out to the piia's this spring lol. Just change the hi beams, ( I'm assuming you have the quad lamps..) as the low's did not toss any more light out vs. stock bulbs.
Even still, they are shite. Did put 100w bulbs in the driving lamps and that is working well.
2011 HD StreetGlide, 103" 106 TQ
2012 Polaris Assault 800 101 TQ
2011 Cummins 800+ TQ
Torque, it's what moves you...
Old 11-28-2010, 02:53 AM
Win's Avatar
Win Win is offline
Rep:99
Win will become famous soon enough
Originally Posted by earlzie View Post
ok so i am beyond pissed right now... so i went outside to swap headlight bulbs and throw some mud flaps on and my god.... looking at the instructions posted above i thought it might be easy.. so i went to change them and holy crap do you really need to take apart the freakin front end to do this????? i went to the dealership n they told me their "trained tech's" take 45minutes to do it with all the right tools... WHY CAN'T DODGE MAKE IT SIMPLE??????????????
i know lots of you have changed them and its not impossible but what happens if for some reason your bulbs burn out at night... you can't take your truck apart on the side of the road.... every other vehicle manufacturer can produce a truck that takes 2 seconds to change bulbs incase of emergency.... anyways this is more of a rant than anything... i did my best to not swear but holy @%#%$@#% the words that are going through my head right now that could describe how i feel about the engineers at dodge right now!!! other than that nice truck... someone come change my headlights for my and put on my mudflaps lol
Lol a "trained tech" at the dealer takes 45 minutes do change the bulbs?!? hahahahaha sounds like piss poor trained technicians to me! I'm a tech at a dodge dealer and it definately does NOT take 45 mins to change the bulbs lol! Release the lock from inside the access panels in the fenders, take the front grille off (4 10mm bolts), put your hand down to the bottom of the backside of the grille and pull to the front of the truck (they are snapped in pretty tight), then take off the remaining 10mm bolts for the headlamp assemblies. Honestly a "trained tech" should be able to do this in 20 mins disassembled and reassembled.
Tools required: Trim stick, 10mm ratchet or wrench, small pocket screwdriver.
Old 11-28-2010, 07:00 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
I just use a 30 inch extension and a piece of shop-grade paper towel to get at the two lower bolts behind the grille. I don't see why you need to touch the grille at all - the paper towel is used to place over the bolt and hold it tight in the socket so it can be lifted out with the socket/extension.
The rest is easy to get to.
Old 12-02-2010, 08:38 PM
05 bee 05 bee is offline
Color: Deep water blue/light sandstone
05 bee is on a distinguished road
what about reaching thru the acess door in the wheelwell..... looks like it might work
Old 12-02-2010, 10:13 PM
Max Power Max Power is offline
Vehicle: 2011 Ram Sport
Color: Deep water Blue
Max Power is on a distinguished road
Originally Posted by Toms Blue Ram 1500 View Post
Thanks for the help Randy .
Ditto here as well!
Old 01-19-2011, 01:22 AM
steve4261 steve4261 is offline
Vehicle: 2011 dodge ram big horn
Trim Level: chrome bumpers
Color: gray
steve4261 is on a distinguished road
45 minutes! If you look inside the front wheel wells you will find an access door! Look inside the door! You will see light bulbs! Stay calm!GRRRRRRRRRR!
