Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
MOPAR DECALS
Old 11-26-2010, 01:37 PM
husky husky is offline
Vehicle: 2010 dodge ram
Color: silver
Rep:37
husky is on a distinguished road
Default bilstein shocks?
I have read that you can get a little lift out of bilstein shocks. ? is which shocks and how much will you gain just by doiing the swap. Also would this take place of the spring spacers.
2010 dodge ram quad cab is the vahicle..
Old 11-26-2010, 01:46 PM
Color: silver
Rep:37
ok scratch the question..it is all over this site..lol what about bilsteins with a small spacer kit like 1"? i was going to go 3" spacer and 3" body but if i could go 2.75 shocks and 1" spacer. Pretty new to the 4x4 scene so this may be a dumb ?
Old 11-26-2010, 04:14 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
I'm sure you could do a small spacer with the shocks. my supplier told me I could put one in the rear with the shocks so the front should work too. I have put the front and rears in and on the second highest setting got 2 1/4" lift on the front with a much improved ride quality
Old 11-26-2010, 07:57 PM
Color: silver
Rep:37
Thanks for the reply...not sure which route ill go yet.
Old 11-28-2010, 01:55 AM
ScatPak07's Avatar
Rep:970
The Bilstein shocks will raise the truck between 2-2.5" on the highest setting. If you throw on a spacer you will add some lift which is a cheap and easy way to lift the truck. The only problem with lifting the truck so much without any other modifications to the suspension is you mess around with the angles. If you mess with the angles of the driveshaft and CV shafts too much you will start to cause problems. If you go with the Bilsteins at full and a 1" spacer you should be alright. The Bilsteins are a great way to lift the truck, the shocks themselves are very comfortable.
When you get yourself into a full lift kit it comes with everything you need to properly set the truck up. Lift kits come with a subframe which will lower the front differential. In dropping the front diff it corrects the angles of the CV shafts. Also they come with driveshaft spacers, this helps extend the length of the shaft. All these little things is why the lift kits cost more then a set of shocks and spacers. It is well worth the money and you will be much happier with it!
Old 11-28-2010, 10:55 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
Yup, I agree. ScatPak speaks the truth about this.
2016 3500 Laramie MC: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
