Old 11-26-2010, 09:37 PM
MOPAR stallion's Avatar
MOPAR stallion MOPAR stallion is offline
Vehicle: 1997 Dodge Ram 1500
MOPAR stallion is on a distinguished road
Lightbulb check engine light code, please help interpret!
Hey all,
Just got my trucks check engine light code read by my buddy who had a reader, the code was:
P0304 cylinder 4 misfire
Like i stated in a previous thread the light will be on for something like 2 days and then be off for a whole day randomly its never consistant
i was planning on doing a full on tune up tomorrow including spark plugs, spark plug wires (these will be ordered), oil and filter, radiator fluid, maybe some seafoam or lucas, clean the k&n air filter
what other things should i do to try and fix this problem? is this a common code? any success stories out there? i hope i can try and fix this on my own, but let me know if i can figure out what the problem is or should take it to the shop
looking forward to hearing any input from you all, i am very new to these trucks but not dodge vehicles in general and would say am an amateur when it comes to engines (definitely not expert, but have been wrenchin for a little while now)
thanks!
Old 11-26-2010, 10:28 PM
I push the skinny pedal
Rep:3277
I'd also replace the cap and rotor, the ACCEL products are good, and this is part of a complete tune up. The rest are all good, as well as the idea of doing the seafoam, just do it BEFORE you put all the new stuff in so you don't risk any sooting up of the new gear. The tune up is all pretty straight forward, just remember to label the plug wires or only do one at a time.
Kurtis
Old 11-27-2010, 03:29 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Make sure you examine the plugs closely, especially the one with the misfire. A plug can tell you alot about how the engine is running. Lay them out in order when you take them out, maybe post up some pics and let the mechanics guide you. Don't forget to clean the throttle body while you're in there: http://ramforumz.com/showthread.php?...+throttle+body. Might also want to check for a plenum gasket leak if you have been using any oil.
Old 11-27-2010, 03:35 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^ Excellent Advice ^^^^,
You may also want to compression test the cylinders and see if the #4 is consistant with the others or not.
Old 11-30-2010, 02:36 AM
ok sweet thanks for the input so far, i am planning on doing the spark plugs, wires, cap and rotor this weekend so i will take pics of the spark plug for you and post them up
Old 11-30-2010, 02:41 AM
Rep:2640
when was the last time the thermostat, belt(s), & hoses were replaced
Old 12-01-2010, 02:31 AM
no clue, previous owner only put 7000 miles on it in 2 years and really didnt need to do anything... temperature readings have been normal, no overheating issues or smells from the engine...at how many miles are we supposed to change that stuff?
Old 12-01-2010, 11:15 PM
Color: Garnet red
Rep:202
Mine's coming up on 100k, I plan on doing it then as preventative. There's also a bypass hose in there, if you do it, don't forget that one.
