MOPAR DECALS
Old 11-27-2010, 02:50 AM
Zerox Zerox is offline
Vehicle: 2011 Dodge Ram
Color: Brilliant Black Pearl Coat
Rep:25
Zerox is on a distinguished road
Default Best option for leveling my 2011 sport
I am debating which way to go for leveling my ram. I want to level it but not sure if I should go with just the front 2' lift or the front and back. I plan on going with ready lift as everyone seems to say great things about them. I plan on keeping the stock tires on for a while yet and would like to do a 6' body lift in the futures but that won't be for a while yet. Any suggestions?
Old 11-27-2010, 03:04 AM
Rep:3337
If you're just looking to do a temporary level, then a set of 2" spacers is the way to go. Simple install and removal, you just need an alignment after the install. With a level, stock tires won't look bad, so it's cost effective. As for the body lift in the future, unless you upgraded some other suspension components, that much of a body lift can make the truck unstable due to lifting a good chunk of weight over the center of gravity. I know that body lifts are cheaper, but unless you've beefed up the suspension enough to handle it, you'd be putting yourself at higher risk of body roll issues, and anti-sway bars can only do so much.
Old 11-27-2010, 03:05 AM
bigdrams's Avatar
bigdrams bigdrams is offline
Vehicle: 2010 Ram 1500
bigdrams is on a distinguished road
Is it a 4x4 or 4x2?
Old 11-27-2010, 03:11 AM
Rep:25
It is a 4x4,
So it's best to just lift the front and leave the back alone. My friend works at a dealer and can get me the kits pretty cheap. He can get me a Ready lift 2.5' front with the 1.75' back as well for 360.00 the kit retails for almost 600.00 Canadian.
But if just the front 2' is fine i will go with that. 200.00 flat I can get it for
Old 11-27-2010, 03:26 AM
Rep:3337
if you're looking to level, the 2.5/1.75 will still leave you with a rake, the factory specs are almost 2.5" of rake. It's not a big deal if you want to put a bit more height in the rear, it's just not as common; the main reason for lifting all the way around would be to fit oversized tires, which you're not planning... that being said, it's your truck and if you want more height all around, then do it, and let no nay-sayer stop you: one of us here lowered a 4x4... so I say do what you want, and let none claw you in your humor!
Old 11-27-2010, 03:34 AM
Rep:25
lol well said, I'll just get the leveling kit for the front. Is this true or not :
Some people have reported wobbling with the 2.5 but none with the 2' I'd like the 2.5 but 2 will do me fine.
Old 11-27-2010, 11:55 AM
Schmitz's Avatar
Schmitz Schmitz is offline
Vehicle: 2005 Dodge Ram 2500 4x4 QC LB
Schmitz is on a distinguished road
They also don't make a 6" bodylift 3" is the biggest unless you Fab up your own which I would not recommend for a street truck.
2005 Dodge 2500 4x4 QC LB Hemi, 6 inch lift, 37" Cooper Discoverer STT's, Bully Dog programmer, K&N cold air intake performance throttle body, true duals, debadged.... Soon to come 4.56s and wheels, maybe more lift.
1980 Chevy K20 4x4 9 inches of lift 37" Boggers, 402 BBC, 4 spd, D60, 14ff.
Old 11-27-2010, 04:37 PM
ScatPak07's Avatar
Rep:970
Wow 6" body lift?? I would not do that haha. If you want to go that high then do it properly and get a suspension lift.
The leveling kit will look pretty good with the truck on stock tires. Also if you get the level kit that does come with front and rear it would be good to do that and then a 3" body lift. So you should have about a 5"-6" lift with the level kit and the body lift together.
Old 11-28-2010, 01:41 AM
Rep:25
My bad guys I meant 6' suspension
Old 11-28-2010, 01:46 AM
ScatPak07's Avatar
Rep:970
Take a look at Performance Accessories. They make a body/leveling lift kit. So they include a leveling kit and body lift to give you a 5" lift. This could be a good possibility since you were looking at getting a lift, and this is cheap compared to others.
You could also use that kit in conjunction with a suspension lift kit to give you one big truck
