Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Old 06-19-2010, 07:11 PM
Quiet Lunatic's Avatar
Quiet Lunatic Quiet Lunatic is offline
Dodge Ram Forum - Dodge Truck Forum - Dodge Ram Club
Vehicle: SRT-10
Rep:434
Quiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enough
Default No control of A/C
My a/c works very well, except for the temperture control. It seems like there is no mid point. I turn the temperature dial till the a/c shuts off, then warm air comes out. When I turn it back to colder, it's freezing. There is no mid point. So I'm wondering if the the temperature control is bad. It seems like some kind of reostat, as I turn it, it has clicks as it is turned. Please advise if anyone has had a simular problem.
Old 06-19-2010, 07:16 PM
Rep:1909
What year is your truck? Different body styles use different control systems.
Old 06-20-2010, 01:22 PM
Vehicle: SRT-10
Rep:434
It's a 2000 Dodge Ram 1500. See attached picture of controls
Old 06-20-2010, 01:23 PM
I wonder if the switch has some dust or carbon on the backside contacts.
Old 06-20-2010, 02:17 PM
Rep:1909
For some reason it would seem the blend door isn't stopping at any midpoints, only full hot or full cold. The problem is I don't know if it's most likely a motor or the controller (knob).
Old 06-20-2010, 03:20 PM
Vehicle: SRT-10
Rep:434
I took the dash instrument cover off, and pull teh control. It looks like all one unit. Not sure, can it be taken a part to even check the contacts for carbon build up? Plus where would I find the "door" that is suppose to modulate between the flow of cold and hot? So ther is some kind of motor on it?
Old 06-20-2010, 03:54 PM
Rep:1909
The blend door is in the HVAC unit and the dash and box have to come out for access.
Old 06-20-2010, 06:22 PM
krb krb is offline
Gender: Not Specified
krb is on a distinguished road
To get the doors,the dash and steering column have to be removed first.Then the HVAC unit needs to be removed from the firewall.
I just went thru this to replace a broken coupling that is between the blend door actuator and blend door.
The door was stuck with the heat on.
Old 08-10-2010, 11:43 PM
Vehicle: SRT-10
Rep:434
You've got to be kidding. Remove the steering column!! OMG Are there step by steps anywhere. Cause now it's stuck in heat mode
Old 08-11-2010, 12:06 AM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Google service manual for your truck.
Brian:
