Old 12-05-2010, 05:30 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
Just don't bury the tach needle in the red.
If you are going to be driving at sustained highway speeds at cruise, vary the speed once in a while.
I like the idea of changing the oil a couple of times ahead of the recommended interval on a new engine.
Otherwise, just enjoy the drive!!!
Hemi tachs have a red line? Mine doesn't, I thought it was just unlimited horsepower and torque.
I think the manual says to drive it normally and maybe vary the speed for the first several hundred miles, but recommends not flooring it for the first few hundred miles
Old 12-05-2010, 10:19 PM
Ram Nut's Avatar
Ram Nut Ram Nut is offline
Vehicle: 2014 Ram 1500 Sport 4x4
Rep:99
Ram Nut will become famous soon enough
From the 2011 owner's manual;
ENGINE BREAK-IN RECOMMENDATIONS
A long break-in period is not required for the engine and drivetrain (transmission and axle) in your vehicle.
Drive moderately during the first 300 miles (500 km). After the initial 60 miles (100 km), speeds up to 50 or 55 mph (80 or 90 km/h) are desirable.
While cruising, brief full-throttle acceleration within the limits of local traffic laws, contributes to a good break-in. Wide-open throttle acceleration in low gear can be detrimental and should be avoided.
The engine oil installed in the engine at the factory is a high-quality energy conserving type lubricant. Oil changes should be consistent with anticipated climate conditions under which vehicle operations will occur. For the recommended viscosity and quality grades refer to “Maintenance Procedures” in “Maintaining Your Vehicle”. NON-DETERGENT OR STRAIGHT MINERAL OILS MUST NEVER BE USED.
A new engine may consume some oil during its first few thousand miles (kilometers) of operation. This should be considered a normal part of the break-in and not interpreted as an indication of difficulty.
2014 Ram 4x4 Quad Sport, 5.7L Hemi 8-Spd, Flame Red, Air Susp - ARE Z-series Topper w/Racks
2011 Ram 4x4 Quad Sport, 5.7L Hemi 5-Spd, Flame Red - 4" Oval Nerf Bars
Old 12-09-2010, 02:14 PM
xlr82x xlr82x is offline
Vehicle: 2011 Ram 1500 Quad 4x4
xlr82x is on a distinguished road
Originally Posted by OldMoparMan63 View Post
More important then HOW you drive it, is changing the oil and filter at the proper intervals and getting the "break in" oil out, with all the tiny metal shavings that are in it from rings wearing into cylinders.
I like to change my oil (on a new vehicle) at 500, then 1000, then at normal intervals.
As others have stated, I drove them like I normally do.
Don't baby it, but don't redline it either, until after at 1000 miles.
After that, all bets were off for me..........
I could swear that my buddy told me that these days after the motors are built, they are ran and flushed prior to being installed. This makes sense otherwise there would be alot more issues concerning people taking test drives with these new vehicles.
Old 12-13-2010, 12:55 PM
earlzie's Avatar
earlzie earlzie is offline
Vehicle: 2011 dodge ram 1500 sport
Trim Level: crew cab sport
Rep:28
earlzie is on a distinguished road
In my manual it says the very first oil change shouldn't be until 13000km
Old 12-27-2010, 01:58 AM
rick980 rick980 is offline
Vehicle: 2009 Dodge Ram CC Sport 4x4
rick980 is on a distinguished road
If you seen them at the factory on the rolls test you would be surprised to know that these things go thru what is similar to a dyno and sometimes I have seen speeds of 100 mph on the speedo so break it in the way you are gonna drive it all the time that is what I was told by one of the best mechanics I know especially newer cars.
Old 12-27-2010, 02:11 AM
Guinnessboy's Avatar
Guinnessboy Guinnessboy is offline
Trim Level: sport
Color: lighter than black, darker than white
Guinnessboy is on a distinguished road
guys, it has nothing to do with the engine, its all about the tranny...go ahead and do a burn out of the parking lot of the dealer, but dont whine when you have differential issues down the line.
Old 12-27-2010, 10:48 PM
NumberCruncher NumberCruncher is offline
Vehicle: 2013 QC Bighorn Ram
Color: Max Steel
NumberCruncher is on a distinguished road
A very valid point. Whether it is a dirt bike or a new car/truck so many people talk about the engine and often times seating the rings properly. I think the rings are probably about seated in the first few miles but the rest of the drivetrain can use a little TLC for the first few hundred miles.
NC
Old 01-04-2011, 10:05 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Todays engines are ready to go...no break in needed. Now as mentioned the tranny is the key to your success. My Lightning came out out of the lot with white smoke coming from it too like mentioned above! I drive that truck like it was supposed to be driven hard...it still runs low low 12's with the stock motor, stock tranny and some bolt ons of course.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 01-04-2011, 03:13 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
I drive my new vehicles like I would normally, no special treatment.
Then before the first thousand miles, dump all oils, and change all filters, and refill.
Its not a mistake that mans best friend cannot talk.
Old 01-04-2011, 03:15 PM
joey0480 joey0480 is offline
Trim Level: Crew Cab Sport 4x4
Color: Brilliant White
joey0480 is on a distinguished road
I don't believe in a break in. Just regular maintenance......
Sylvania 9145ST, H11ST, and 9005ST, Cortex 3950, K&N filter, Magnaflow 12198 and Y-pipe 10778
