Old 11-28-2010, 12:12 PM
Default Engine block heaters
I've noticed here recently that there has been quite a few discussions on engine block heaters . Just a little heads up to those of us who don't have a block heater and would like to consider doing one for themselves . I work at a plant where we have a couple of emergency backup systems (backup power and fire pump systems) . They are designed that once they start up , they run full throttle (3000 rpm) . Now you know that if you start up a cold motor and run it full throttle that it's not gonna last . These systems are designed to do just that . I've been getting our systems ready and serviced for the upcoming cold weather . I noticed that these block heaters are easy to install and not that expensive . They get installed in a heater hose and circulate the warm coolant through out the whole motor . I've been impressed with them . I'm considering doing a install on my Ram . Heres a pic of what it looks like . This one is made by Generac . They can be purchased through your local Grainger or Home Depot .
File Type: jpg 613fc1fe-0d91-4456-ba43-b62d05a52d05_300.jpg (9.3 KB, 28 views)
Old 11-28-2010, 12:14 PM
Rep:1885
I've seen similar setups in local parts stores but for the life of me I can't remember who makes them.
Old 11-29-2010, 04:05 PM
Spencer the EMTI's Avatar
Spencer the EMTI Spencer the EMTI is offline
Vehicle: 1995 Dodge Ram
Rep:28
Spencer the EMTI is on a distinguished road
How much do one of these kits cost and how har is it to install one of these in you driveway or garage?
"Life is tough, it's even tougher when you're stupid."
-John Wayne-
Old 11-29-2010, 08:17 PM
I haven't researched the price . You can go to Home Depots site and search for it . But it's basically cut a heater hose and install it in the cut hose . Find a way to mount it to the body and run your power cord . The one in the photo looks like the ones I work on and they work well .
Old 11-29-2010, 08:23 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
How does it push the fluid past the closed thermostat? Do the newer Rams that use a knob to set temp have to be turned on, set the temp and then turned off?
Brian:
Old 11-29-2010, 08:49 PM
I'm not sure if the newer Rams have a heater control valve . All the ones I've seen haven't . The coolant is constantly flowing through the core .
Old 11-30-2010, 11:13 AM
ramsport99's Avatar
ramsport99 ramsport99 is offline
Vehicle: 05 Ram quad cab
Trim Level: SLT 4x4
Color: light almond pearl
Rep:42
ramsport99 is on a distinguished road
I had one in a vehicle years ago. It was great, you have heat right away defrost right away. Don't know why I haven't put one in this truck. Just might have to.
If you're goin through hell keep on goin
Freedom isn't Free
Old 11-30-2010, 07:14 PM
pieece's Avatar
pieece pieece is offline
Vehicle: 03 Dodge Ram 1500 QC 4X4 5.7H
Color: Two Tone - Grey/Silver
Rep:38
pieece is on a distinguished road
What he said...
I will def. install one once I find out a little more information about them.
17" Eagle Rims/2" Leveling Kit/33" Nitto Terra Grapplers/Billet Grille/K&N CAI/SUPERCHIP/-5% Tint/Black Chrome Running Boards/Black Chrome Light Bar/Behind the Grille Running lights - HALOS/4 100W KC Daylighters - Black/Fire-Ice Bar/Recon Smoked LED Cab Lights/Electronic Safe/
Old 11-30-2010, 07:25 PM
It doesn't need to open the thermostat , it heats the coolant up by circulating the coolant through the heater hoses then back through the block . The engines that I work on at work have thermostats in them too . I can go touch any part of that engine and feel the warmth . I think the temperature is right around 130 degrees .
Old 11-30-2010, 07:44 PM
pieece's Avatar
Rep:38
Looks pretty easy to install by yourself. Kit runs at 150$ http://www.homedepot.com/webapp/wcs/...atalogId=10053
