Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 11-28-2010, 07:04 PM
1BadassHemi's Avatar
1BadassHemi 1BadassHemi is offline
Vehicle: 2006 Dodge Ram
Trim Level: Big Horn 4x4
Rep:48
1BadassHemi is on a distinguished road
Arrow What type of oil to use?
I have an 06 1500 Hemi with 58,000 miles and I'm wondering what kind of oil I should run. I heard that you have to run 5w 30, due to the MDS, if you don't then it will mess up the timing of the MDS. I was wondering if synthetic would be a good choice or not?? So pretty much just want to know, synthetic or regular, and what brand is best? Thank you!!
2006 Dodge Ram Big Horn 4x4
SuperChips Cortex, K&N Intake, Muffler delete, Bilstien Leveling shocks, 34" Copper Zeon LTZ
Old 11-28-2010, 07:29 PM
Rep:2705
starting in 2006, the Rams got the MDS system & it REQUIRES 5w 20
If you have an MDS engine (all current 5.7 engines!), only use 5W20 oil. You need the right oil. If the owner’s manual says something else, follow its advice - but don’t be convinced by a mechanic. Insist on the right grade and if they don’t use it...get a refund and go somewhere else. (You can quote TSB 09-015-04 and 09-013-04, “Vehicles with the Multiple Displacement System must use SAE 5W-20 oil. Failure to do so may result in improper operation of the MDS.”) Read more at http://www.allpar.com/mopar/new-mopa...ktrack=kcplink
In my opinion:
Mobile 1 5W-20 synthetic. You can run dino oil if you prefer, it's totally up to you and won't have any adverse effects
Other good oils are Royal Purple, Castrol, & Amsoil
I like the Mobile 1 myself because even Walmart carries it, usually $22 for a 5 quart jug
As far as oil filters go, Mopar, Wix, & Napa are considered 3 of the best for the Hemi
i use the K&N air filter
Old 11-28-2010, 07:35 PM
I push the skinny pedal
Rep:3308
Well, it's actually 5W20 you want to use. As for which is better... that will be debated until he end of time I used to use Amsoil, but due to difficulties in getting a hold of it, I switched to Royal Purple. Most people use the Mobil 1 synthetic to good effect. The benefits of a good synthetic out weigh the additional cost; with better lubrication, wear reduction, and longer between oil changes.
Kurtis
Old 11-29-2010, 02:28 PM
Rep:48
Thanks guys!! Ya that was a typo on my part i meant to say 5w20, I heard good things about Amsoil, There are about 3 dealers within 15 miles of my place so getting that wouldn't be too hard for me! I think I'm gonna go with a synthetic oil and a NAPA oil filter!! Thanks for your input guys, it really helped!!!
Old 12-03-2010, 01:05 PM
dsmoore2991's Avatar
dsmoore2991 dsmoore2991 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Slt
Color: Grey
dsmoore2991 is on a distinguished road
I use Ams Oil i think its the best for our engine its 25,000 miles to a year before another oil change.
DmOoRe
Old 12-04-2010, 06:24 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
I use 5W30 I have almost 80,000 on my truck, need a little thicker as the engine breaks in but not too thick and my truck is super smooth. I use Valvoline Full Synthetic and love it... also I use a K&N Oil Filter, costs more but worth it!
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 12-04-2010, 06:48 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
I use Amsoil 0W20 with a Wix (UAP NAPA Gold) Filter. Stuffs fantastic !
sales@revelperformance.com
Old 12-05-2010, 10:09 AM
von6324 von6324 is offline
Vehicle: 2005 Ram 1500 SLT qd cab 4x4
von6324 is on a distinguished road
Default Oil
I don't recommend synthetic due to the fact that if you don't like it, they say you are not to go back to regular. Far as the 5w-30 to something else, that depends on the type of enviroment that you are in. I run 10-30 in my truck, but I have also seen others us 10-40. You don't seem to have a lot of miles on, so you could easily use the 10-30 if you wanted too and it will not harm your truck in anyway.
Old 12-05-2010, 10:30 AM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^ Wrong ^^^ The HEMI with MDS requires 5W20 as stated in the owners manual. As for synthetic v.s. Dino its a personal choice. Synthetic will allow for longer drain times and is less likely to sludge. Dino's fine if you change frequently. Nothing wrong with switching back and forth but why would you ????
Old 12-05-2010, 11:40 AM
bigdrams's Avatar
bigdrams bigdrams is offline
Vehicle: 2010 Ram 1500
bigdrams is on a distinguished road
On that amsoil website it said that the oil change it is every 25000 miles or every ones a yr. Is that right?
oil
