Old 11-28-2010, 10:35 PM
sherker55 sherker55 is offline
Vehicle: 1996 1500 2wd
sherker55 is on a distinguished road
Default 2nd Gen 1500 2wd
HI everyone, I'll keep this short and sweet as this is for a friend of mine. 1996 1500 5.9 2wd 145k miles. Suspension sucks and he wants to upgrade, everything is sagging and shot! I searched for swapping a 2500 or 3500 suspension but only found 1 thread. Can it be done, and if so, what will we need (besides obvious, like springs shocks, eetc) Thanks in advance!
Mark
Old 11-28-2010, 11:21 PM
I'm not sure it can be done . I would say rebuild what he has .
Old 11-28-2010, 11:43 PM
Rep:2616
springs can be re arced & they can add an extra leaf
there are several places that do it, places all over the USA & Canada
they do Spring Repair Re-arch, Repair, Rebuild, Leaf Additions, Overload Additions
here is a bit of info about it
http://www.eatonsprings.com/rearching.htm
Old 11-29-2010, 01:18 PM
Awesome thanks guys...I was thinking of going to the 2500 springs and leafs to give it a higher stance, it looks like a low-rider! having the extra height wouldn't hurt because he also wants to go with bigger tires/wheels (seems like all 94+ rams have same bolt pattern & size)
Old 12-09-2010, 08:30 PM
96DodgeRam1500's Avatar
96DodgeRam1500 96DodgeRam1500 is offline
Vehicle: 1998 Dodge 2500 4x4 Sport
96DodgeRam1500 is on a distinguished road
Ive heard that it can be done.. but only with a 2nd Gen 2500... the rear leafs ive been told will bolt up in the same holes. the only thing you would have to do is drill out the holes on the 1500 for the 2500 bolts because they are bigger. Shocks off a 2500 should bolt right up in the rear. front would basically just be the springs out of a gas burner 2500.. diesel coils will not work. upper and lower a-arms should bolt up... i recommend getting a 3" lifted spindles. Theyre on ebay for $300 a pair.. and you would just need shocks.. you would need wheel spacers if you go the spindle route. Because you would need a mininum of 4 1/4 backspacing.
1998 Dodge Ram 2500 Sport 4x4. 360 all stock. Leveling kit with 315s.
Old 12-09-2010, 08:32 PM
Also, dont try gettin a 4x4 2500 and expect it to work on the 1500. It would have to be a 2WD also.
