Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
tonneaucovered.com
Old 08-13-2010, 01:53 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Default Drone Fix - Cheap Way
I see a lot of posts from people that want to get rid of the "drone" supposedly caused by the MDS after they've put on an after-market exhaust.
The most recommended cure is to buy a tuner and turn off the MDS. This works well, but if the drone is your ONLY issue that you intend to use the tuner for, its a very expensive fix.
The easiest way I'm aware of to turn off the MDS is to press the Tow/haul button. When the Tow/haul is lit on the dash, that means you are in Tow/haul mode, not economy mode. This turns off the MDS.
Personally, I like the MDS because it saves me money. But I also have factory dual exhaust.
Brian:
Old 08-13-2010, 02:43 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I thought the cheapest way would be leaving the stock muffler on...
Muwahahaha!!!
Old 08-13-2010, 03:02 PM
LOL @ chithead
Old 08-13-2010, 05:22 PM
Color: RootBeer
Rep:1287
Muwahahaha!!!
Very true.
Brian:
Old 08-15-2010, 05:21 PM
PB1500SLT's Avatar
PB1500SLT PB1500SLT is offline
Vehicle: 2008 Ram SLT
PB1500SLT is on a distinguished road
So the only difference of tow/haul mode and regular driving is it turns off the mds?
Old 08-15-2010, 05:29 PM
ScatPak07's Avatar
Rep:970
That is a pretty easy fix for the drone. The only thing is that it will suck the gas right out of the tank haha. At least the tuner will help out with the MPGs not kill it.
Old 08-16-2010, 03:02 PM
Color: RootBeer
Rep:1287
Not quite.
Tow/haul mode (light on) removes the overdrive when driving hiway speeds and it also cuts out the MDS at all speeds.
Without the tow/haul light on, you are in overdrive at hiway speeds.
Brian:
Old 08-17-2010, 02:38 PM
08BigHorns's Avatar
08BigHorns 08BigHorns is offline
Vehicle: 08 Hemi Ram Quad Cab 4wd
08BigHorns is on a distinguished road
That's good info to know, never knew what the tow/haul did?
Old 08-17-2010, 03:04 PM
tmerritt530's Avatar
tmerritt530 tmerritt530 is offline
Vehicle: 2004 Ram 1500 4.7L "H/O"
Color: Graphite Metallic
Rep:91
tmerritt530 will become famous soon enough
It also has different shift points. It holds lower gears longer and downshifts sooner
2004 SLT RCSB 4.7L | 3.92 | OEM Off-Road wheels | Goodyear SilentArmor 285/70R17's | dumped magnaflow | H/O cams | H/O cyl heads | 10" Rockford Fosgate P1
Old 08-17-2010, 08:07 PM
Flaminchiten Flaminchiten is offline
Vehicle: 2010 Ram 1500
Rep:42
Flaminchiten is on a distinguished road
I thought it removed the torque converter lock up but still allows the truck to shift into 5th gear. Please correct me if I am wrong.
