Old 12-01-2010, 01:35 PM
outinthefield outinthefield is offline
Vehicle: 2003 Dodge Ram 1500 Laramia
Trim Level: laramia
outinthefield is on a distinguished road
Default 6" Lift, 17x8 Rims Whats the biggest tire i can fit
Hi there..
Im lifting a 2003 1500 laramia 6" & was wondering if i could pu 35x12.5R16.5 BF Goodrich All Terrain's on the stock 17x8 Rims.. or whats the biggest i could go??
Old 12-01-2010, 07:59 PM
srt93 srt93 is offline
Vehicle: 2006 dodge ram 1500 4x4
Trim Level: laramie
Rep:55
srt93 will become famous soon enough
depending on the lift kit but ive never heard of a six inch lift not being able to clear 35's most can run 37's with a little rubbing
Old 12-01-2010, 08:37 PM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
My buddy run's 35's with a level kit!!!
Old 12-02-2010, 06:37 AM
Trim Level: laramia
Thanks for that.. Im going to put some 35" BF All Terrains under it...
Old 12-02-2010, 07:51 AM
iRESQu iRESQu is offline
Rep:2217
I had a 6" lift and 37x13.5 on 17's and rubbed only slightly at full crank. So I would think it safe to say you CAN run 35's.
Old 12-02-2010, 07:53 AM
35's for sure!
Old 12-05-2010, 12:35 AM
ScatPak07's Avatar
Rep:970
Yep you will be able to fit the 35" tires no problem. I am running that same set up, 6" lift with 35" tires (not the same tires). I also have 13.5" wide tires and still no rubbing, so you should be fine.
Old 12-05-2010, 12:49 AM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
Check with the lift manufacturer (you weren't specific) I know that on some IFS trucks like yours you can't roll on stockers with aftermarket knuckles and drop brackets.
SUL73NAZ
Old 12-05-2010, 01:01 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Agreed but Ill be surprised if ya cant pull off 35x12.5s Im pretty sure ive seen people on the site running that size stock
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 12-05-2010, 01:03 AM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
You can fit 35s with no rubbing easy!
Dillon-aka, The Little Kid
