Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-02-2010, 10:22 AM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Bout to get some gas and matches >:/
I've been having some heat related problems amidst a bunch of others but this one is confusing me to no end. Long story sort i replaced the thermostat multiple times, flushed the system and finally came to the conclusion that the heater core was bad...had that replaced and it worked fine...recently went on a trip back home and it worked the whole way there and back....when i was back home we noticed that the coolant was low so we discovered the leak and fixed it...filled it with coolant and seemed to be fine on the way back...after i got home and i got up the next day (9 degrees outside) the truck would not blow hot air! After driving for 45 min the temp gauge appeared to be a little lower than usual but i think thats cause i was driving down the road at 65 mph with it only being 9 degrees out....needless to say i have no heat in the cab but i checked all the hoses and they appear to be hot (radiator and heater core hoses)...what is going on?
Old 12-02-2010, 10:25 AM
Rep:1890
You sure you have the correct mixture of coolant and water? If it's weak it could have frozen up in the core.
Old 12-02-2010, 08:29 PM
alfonso318's Avatar
Rep:42
Yah we made sure that it was -34 Degrees capable...
