Old 12-02-2010, 11:09 AM
oldseabee67 oldseabee67 is offline
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
oldseabee67 is on a distinguished road
Default Cummins 24 valve power steering pump.
Hey all! Hope everyone had a good Thanksgiving! My concern today is my 99 3500 2 wheel drive dually's power steering pump. It appears to have developed a leak, but after I changed engine oil yesterday, I laid under and watched it while running the engine. It almost seems to be engine oil, as it is darker than p/s fluid and smells more like diesel crankcase. Leak appears to be coming out dead center of the pump. I only have had to add less than a pint in last 4000 miles, and steering is quiet when turning, no buzzing or noises. Truck has 158,000 miles on the odometer. Support our Troops! Dale
Old 12-02-2010, 11:37 AM
Rep:1885
Get some dye and add it to your p/s fluid. Run the truck a few days and then check for leaks that glow from the dye.
Old 12-14-2010, 01:26 AM
jd322 jd322 is offline
Vehicle: 99 24v ctd
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
jd322 is on a distinguished road
Sounds. like blow by is it a diesel?
