Cargo bed dividers? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-02-2010, 05:32 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Default Cargo bed dividers?
Hey guys -
I currently run a bed divider in my truck - just one of those poles that you can extend and then tighten with a ratcheting mechanism. Problem I've had with it is that heavy objects will knock it loose, and it causes issues if I can't seem to get it at exactly the right height and what not. Are there any cargo dividers out there, kind of like the one that comes with the Ram Box, that you guys have had success with? I carry a lot of small crap back there as the Ram is our main family vehicle.
I've done some searches but haven't really found anything, beyond the bed dividers that you have to bolt in (the ones that swing out).
Any suggestions?
Thanks in advance -
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2017 Dodge Durango GT
2012 Jeep Grand Cherokee Limited (SOLD)
Old 12-02-2010, 06:30 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
Many bedliners have pockets to insert 2x wood dividers. I'm not a big bedliner fan, but that it would give you that ability.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 12-02-2010, 06:53 PM
Rep:2954
yes, the best & cheapest way is to buy some 2 X 6 lumber, measure twice, cut once
you can see the vertical slot between the inner fender & the tie down loop by the tailgate, there is another place on top of the inner fender if you would need a horizontal plank, i don't recall if there is another Vertical slot in front of the inner fender
a second way is the Mopar OEM Dodge Ram Sliding Bed Divider 09-Up
Description: Bed Divider -- Must be used with Mopar Pickup Box Utility Rails (sold separately)*
Item Number: 82211493
MSRP*: $338.00
Part Note:
Installation Guide:
Vehicle Description: 2009 & up Ram 1500
Old 12-02-2010, 08:10 PM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
I tried some of the cheepo bars made in China and had the same problem keeping them in place.
Found this: http://www.saveaload.com/pickup-truck-bars.htm
This bar will not shift position and is a lot stronger.
Old 12-03-2010, 12:55 PM
Turbovsix's Avatar
Rep:85
Well, that sliding Mopar divider is exactly what I'm looking for, but holy crap is that expensive. I wanted something more elegant than a piece of wood, plus I wanted to be able to move it around. Already have the bedliner, etc.
That Save a Load bar is interesting as well, but I was really looking for something that would divide up the bed from top to bottom -
Thanks for the suggestions all - maybe I can get Santa to add that bed divider to my list....
Rich -
Old 12-03-2010, 02:58 PM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
MSRP*: $338.00
Part Note:
Installation Guide:
Man... that is one CLEAN truck bed! Has it ever had ANYTHING in it???? lol.
Ambitious, but rubbish!
Old 12-03-2010, 03:09 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
He carries an oversized load sign, if that tells ya anything
Old 12-04-2010, 10:46 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
I use the pole type that you can tighten, the only thing I have found is on some areas the interwall will flex. Juat find a solid point when placing the pole
Old 07-30-2014, 10:40 PM
Mgoblue297 Mgoblue297 is offline
Vehicle: 2013 1500
Mgoblue297 is on a distinguished road
Why can't they just make the same as the ram box for trucks with out it. It's to bad that doesn't fit in the regular trucks I would buy it now
