Old 12-20-2010, 06:08 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
Thanks for the update.. Im sure it will all work out in the end but i know its rip your hair out frustrating.... you have all of our support!!!
Old 12-20-2010, 06:14 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Geez Paris, that really sucks.
Is BellTech/Summit going to foot the bill for the repairs they have caused as well as all shipping of returned parts since the whole thing is their screw up?
If not, they should be.
Brian:
Old 12-20-2010, 08:26 PM
Rep:1625
Brian's right, I understand the cost of an alignment being on you, but all those other expenses should be on them. I hope they get everything straightened out soon. Keep us posted, Paris!
Old 12-20-2010, 09:24 PM
Hang in there, Paris. This will all work out. Just keep at 'em. I know you and Scott know what to do to keep Summit and Bell Tech on track here. (no pun intended )
Old 12-20-2010, 09:30 PM
iRESQu iRESQu is offline
Rep:2217
Thanks you guys! As of tonight, Belltech nor Summit have yet to return Scott's call. Last we knew Summit was speaking with Belltech and determing return and reissue procedures as well as any reimbursement for THIS alignment. Scott is highly pissed, as am I, and they are both getting it from us tomorrow.
Old 12-20-2010, 11:16 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
A regular cab kit eh... you know I've been eyeballing the BellTech kit since you installed it... and the wife has said she wouldn't mind my truck being lower after she drove it around the other day... would it be ok if I talked to her tonight about buying this kit from you? (if that's an option you and Scott would consider)
Old 12-21-2010, 12:19 AM
Rep:2217
Scott said he will call you tomorrow before he calls Summit and Bell Tech and discuss the specifics with you. No rush, we can plan another g2g if everything goes through.
Old 12-21-2010, 12:23 AM
Color: RootBeer
Rep:1287
Ok, call me stupid. But to me the suspension is the same regardless of type of cab, right? Or is this a body kit and therefore cab type specific?
Brian:
Old 12-21-2010, 12:27 AM
Rep:2217
It is a spring strength and compression ratio issue. The Crew Cab being longer and heavier, needs stiffer springs with a higher compression ratio than a regular cab. Therefore, if you put regular cab springs on a crew cab, the crew cab compresses the springs farther than they should or were designed to. (I would NEVER call you "stupid")
Old 12-21-2010, 12:53 AM
chithead's Avatar
Rep:2078
I hope this works out for you. That sucks they sent out the wrong kit. Maybe the new one will be even better for your sweet sekzy Ram.
Will I still need a camber kit?
