Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-02-2010, 08:29 PM
B and B LANDSCAPES B and B LANDSCAPES is offline
Vehicle: 1999 Dodge Ram 2500
Trim Level: base
B and B LANDSCAPES is on a distinguished road
Thumbs down Vents change to defrost under load
My vents work fine except it changes automatically to defrost when i put the engine under a load ( like full throttle or change gears too quick and have rpms real low) then when the engine gets out of its struggle they change back to where ever i have it set.... My last dodge truck started doing this right before i sold it so i never looked into it... both trucks didnt do it at first but started... anyone care to elaborate what normally would cause this?
Old 12-03-2010, 09:00 AM
Rep:1890
A bad vacuum check valve can cause this. It's located in the vacuum line that runs into the cab.
Old 11-04-2011, 08:34 PM
xnumnutsx xnumnutsx is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT laramine
Color: inferno red
xnumnutsx is on a distinguished road
do you know exactly were i can find this valve? cause i have this same problem on my truck and it is so annoying!
Old 11-24-2011, 04:26 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If memory serves me correctly...Pass side of the intake there's a line that comes out under right where the throttle cable is. Follow that line and look for the off-white and black inline valve. If not...follow the vacuum line that comes out the passenger's side firewall and look for the same valve in the vacuum line.
Old 11-24-2011, 06:12 PM
Color: inferno red
good shit! ill do that tmrw!!
Old 11-25-2011, 09:22 AM
Vehicle: 95
Rep:1776
...and pick up a bar of soap while you're at it young man... sutch a potty mouth...
and don't forget to give our member's a rep if they help you out...
...I'm feelin' pretty unf'n appreciated right about now Carl...
Old 11-25-2011, 12:44 PM
Color: inferno red
how the hell do i do that?
Old 11-25-2011, 01:19 PM
Take a look at the Newbie How To's on giving and receiving Reputation.
And I agree...let's cut back on the 4 letter words a bit...
Old 05-05-2012, 10:43 PM
KdkGrizz KdkGrizz is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Blue
KdkGrizz is on a distinguished road
Send a message via AIM to KdkGrizz
Default Stumbled across this post thankfully
Warlock, Thanks for the good info. I was noticing this issue with the vents this past weekend while pulling my camper. I was trying to sort it out in my mind if it was a trans issue, or a vacuum issue. Glad to know I was on the right track...
I will search out the check valve, and replace it. I think while I am at it I might just replace the throttle position sensor. Been having some erratic shifting in the top end gears.
Be good and thanks for the info...
Grizz....
Old 05-07-2012, 03:25 PM
Color: Blue
Default Not the check valve.
Well guys. Pulled and replaced the check valvue in question. No change. Now I fear that I am going to have every vacuum ling under the hood and in the passenbger compatment looking for a leak......z
Any other suggestions......
