Vents change to defrost under load - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-07-2012, 03:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Replace any cracked/rotten vacuum lines that pass through the firewall. It should be a cheap and easy job. Just do one at a time so you don't mix up the routing.
Sean
Old 05-17-2012, 10:40 AM
KdkGrizz KdkGrizz is offline
Vehicle: 2011 Ram 1500
KdkGrizz is on a distinguished road
Send a message via AIM to KdkGrizz
Still can't figure out the vent to defrost issue. Not such a big deal except that we are coming into the hot part of the year and doing a lot of towing, camper, boat, etc and losing the A/C on long hills has the wife complaining already and it's only May.
Anyone out there got any ideas of where else I might search for a vacuum leak?
Also have noticed recently that when I am on the expressway at 70 with the cruise set the engine surges from time to time. 2000 - 2200 rpms. Trans doesn't shift, just rpm surges only last 1 second or 2.....Very strange.....
Be good all..
Grizz.....
Old 06-04-2012, 07:22 PM
Hey guys wanted to share this one with you. The problem with my 2000 turned out to be the speed control servo. Once I bypassed it the vents were fixed, and the transmission started shifting better. But I lost my cruise control. So I went searching online for a new servo, and just by luck happen to find out that my 2002 Dodge Intrepid that I am getting ready to donate uses the same servo...hmmm So I pulled the servo from the Intrepid and put it into the Ram. Now I have vents when I need it and cruise when I want it.....Hope this helps someone out there....=))
