Old 12-02-2010, 09:15 PM
dodgepwr05's Avatar
dodgepwr05 dodgepwr05 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Lone star
dodgepwr05 is on a distinguished road
Default overheating
when i sit in one spot it wont over heat but when i get to driving itll rise between the middle line and the red line but when i turn on the heater itll cool down. iv called different dealers and most have them told me it could be a clogged radiator.it has 77 thousand miles. the heads arnt blown and nothing is leakin so it couldnt be the water pump. the only thing that comes to mind is either the thermostat or the radiator being clogged. what do yall think and how could i go about fixing it. i cant tell my wife cuz i just bought the truck and she wouldnt be too happy about this. thanks
2009 Dodge Ram 1500 CC SB
5.7L Hemi
Old 12-02-2010, 09:23 PM
Rep:4072
That sucks man, usually, I have the problem in reverse, at idle is when I heat up and while driving it cools down. Why not flush the radiator and see how that works? I used the Prestone radiator flush and never had a problem with it. I still ended up needing a t-stat though, but good luck and I'm sure others here will have better advice for ya. Pretty young a truck to be having that problem.
Old 12-02-2010, 09:27 PM
Are you sure it's overheating . It could be a inaccurate guage . If it is overheating it could be anything . Bad thermostat , head gasket , bad radiator etc...
Old 12-02-2010, 09:44 PM
dodgepwr05's Avatar
how would i know if it an inaccurate gauge? yeah ill prolly start at the radiator flush with new t-stat.
5.7L Hemi
Old 12-03-2010, 10:58 AM
dodgepwr05's Avatar
im starting to wonder if it is the gauge cuz last night i had the cold air on and it wasnt over heating all that much. not as much as it normally showed.
5.7L Hemi
Old 12-04-2010, 08:56 PM
dodgepwr05's Avatar
so i did a coolant change and the the coolant in the CLEAN bucket was sandy. so im now lead to believe the radiator is clogged.
5.7L Hemi
Old 12-07-2010, 06:42 PM
liquorbox liquorbox is offline
Vehicle: Ram 1500 2004
liquorbox is on a distinguished road
Default Truck doing same thing
DId you figure it out? I started dealing with that exact thing today. It has gotten very cold here in the past couple of days. IT first started doing it this a.m. at idle i tried to turn on heat and it would not blow hot. Then temp gauge went to exactly where you said and I shut it off. HEater began to work when i started driving. Later in day it started doing same thing turned heater on in movement was the only way to cool it back to normal. Fan clutch was suggested to me as well as water pump possibly.
Old 12-07-2010, 07:22 PM
dodgepwr05's Avatar
is the water pump leaking? if not ur good on that. come to find out the thermostat has a high open temp. i think it opens at 195. u might want to check to see how much coolant is left in the reserve.
5.7L Hemi
Old 12-08-2010, 06:21 AM
Default thanks
As far as I can tell nothing is leaking. I will check coolant level today. I have had truck since new and never had one issue with overheating. I am staring to think thermostat. Thanks for your response.
Old 12-08-2010, 11:20 AM
dodgepwr05's Avatar
it very well could be the t-stat. good luck and let me know what u end up doin.
5.7L Hemi
