Ram Pulling to the left??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-03-2010, 05:56 PM
Aries's Avatar
Aries Aries is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Aries is on a distinguished road
Default Ram Pulling to the left???
Hi everyone, I've had my 2010 Ram Sport quad cab for about two months now. And from day 1, it had a slight pull to the left. On the highway after 3 hours of driving my left arm was sore from holding the truck in it's lane.
Anyway, I had my first oil change done last week, and had them do a wheel alignment, The mechanic said "it was a little off". Anyway on my way home from the dealer that day. it seems to me that nothing has changed. it still has a slight pull to the left.
Yesterday I was talking to a mechanic at work, His boss just bought a 2010 Ram SXT quad cab, And he was saying his truck pulls to the left too.
I was wondering if this is a problem with all of our trucks and it's as they'd say "Normal"???
Old 12-03-2010, 06:31 PM
dubstar dubstar is offline
Trim Level: SLT Quad cab
Color: BBCP
dubstar is on a distinguished road
mine does too, only a tiny bit. but its been there from day 1,
Old 12-03-2010, 06:45 PM
Aries's Avatar
My mechanic friend say's " to play with the tire pressure a little a pound or two, higher on the left and lower on the right. it may help a bit.
Old 12-03-2010, 09:16 PM
steve57's Avatar
steve57 steve57 is offline
Trim Level: ST quad cab 4wd
steve57 is on a distinguished road
Some of the trucks are hard-core democrats. Mine is a centrist.
Old 12-03-2010, 09:21 PM
Btreat003's Avatar
Btreat003 Btreat003 is offline
Vehicle: 2010 Dodge Ram Sport Crew
Rep:26
Btreat003 is on a distinguished road
My 2010 does the same thing.... was going to take it back to the dealership but figured they'd blow it off....
Old 12-03-2010, 09:35 PM
crowned roads will give that affect as well. Try playing with the tire pressure. Did you get a report on the before and after alignment on your truck in addition to the "it was a little off"?
Old 12-03-2010, 09:45 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Mine did the same from day one (way back when). Took it to dealer and they aligned it and it still kept doing it. Drove me nuts for years until I got new tires. It was a defect in the tires (Goodyear Wranglers). After getting new tires (Michelin), no more pulling, no more alignment problems. Try rotating them and see if it helps.
www.beatcraigslist.com - for posting dangers & secrets
Old 12-03-2010, 09:55 PM
Aries's Avatar
At the same time I had the alignment done I had my winter tires put on.
I thought it was the tires too. but these are a totally different set of tires.
Maybe not the best tires in the world.
I got the Hankook RW11's 275/60/20
I guess I'll just have to stay in the right lane where it pulls less.
Old 12-03-2010, 09:56 PM
Aries's Avatar
I never saw any report. I didn't know they could make a report
Old 12-03-2010, 10:12 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
try to swap the tires from left to right in the front. most likely you have a radial pull. tires aren't defective when they pull some tires just like to spin a certain way. i do alignments all the time and 90% of the time its a tire causing the pull. just cause you change tires and it still pulls dont rule out the tires still....... u might just be that lucky
Too many mods to fit here!
