Old 12-04-2010, 12:09 AM
dgard61's Avatar
dgard61 dgard61 is offline
Vehicle: 2010 Ram Crew Cab, 4x4 Laramie
Color: Inferno Red/Sandstone
Rep:91
dgard61 will become famous soon enough
Originally Posted by RamTex View Post
Ok so im changing my oil for the dyno day tomorrow and this is what i found in my catch can should i be worried? Last time it was a lot darker. The oil from the pan was normal colored.
I emptied my catch can this past week also. My oil in the can was exactly the same. The first time I emptied the can it was normal color too. Hope it's nothing to worry about.
Vent Visor's, Bug Deflector, Chrome Fuel Door, Bak Flip G2 Tonneau Cover, Bed Extender, EZ Down Tailgate Dampener, Line X Spray in Box Liner, WeatherTech Winter Mats, Husky Moulded Mud Flaps, Billet Tech Oil Catch Can, 12" S/S Antenna Mast, Chrome T/G Handle, Mopar CAI, Painted Engine Cover, Billet Tech Polished Underhood Cap's, Front Window Tint, Billet Hitch Cover, Anti-Theft Valve Cap's, MGP Caliper Covers, Retractable S/S Stake Pocket Anchors, Mopar Trailer Brake Controller, Recon LED Light Bar, Polished Billet Lock Pins, Mopar S/S Door Sills, Interior LED's, Mopar LED Cargo Bed Lights, Billet Throttle Body Cover
Old 12-04-2010, 10:34 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
awesome thanks for all the responses i like having this catch can its great to see that all that mess didnt run through my entire engine system WTG CATCH CAN!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 12-04-2010, 09:24 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Originally Posted by HEMILANCER View Post
it probably got moisture in the can from somewhere. i've seen that under oil caps on older cars when the cap doesnt seal well
Originally Posted by sprintertech View Post
probably condensation.....if the oil in the pan dont look like that i wouldnt be worried....
looks like some moisture build up like already stated. Do you make a bunch a "short" trips where the truck doesn't quite get up to temp?
If you want to run a comparo test try putting your OEM t-stat back in and see if your can looks like that at your next oil change.
Old 12-04-2010, 11:06 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Cold air on aluminum catch can,,, hot crankcase fumes on cold aluminum,,,
Condensation be my guess.
Old 12-05-2010, 03:08 PM
TRDon TRDon is offline
Vehicle: 2010 Big Horn Ram
Color: Inferno Red
Rep:20
TRDon is on a distinguished road
Nothing to worry about. It is colder in NE this time of year and you are getting condensation in with the oil, especially in a remote catch can. I got that on the underside of my oil cap every winter.
Old 12-16-2010, 02:42 PM
RamManiac RamManiac is offline
Vehicle: 2009 Ram Hemi 1500 4x4
RamManiac is on a distinguished road
Question
What is a catch can for? Where does it mount? Whats its purpose?
Old 12-17-2010, 02:07 AM
skwurlz skwurlz is offline
Vehicle: 2005 Dodge Ram "Demon"
Color: Graphite
Rep:13
skwurlz is on a distinguished road
Its for catching oil pushed into the intake system by crankcase pressure. Most late model vehicles have a PCV, which makes the engine "burn" the crankcase pressure rather than vent it to atmosphere. Pollution reasons.
A catch can is used to try and "catch" the oil pushed into the intake tract by crankcase pressure.
As for the cafe mocha in the first pic, its normal when in winter months and higher humidity. If the oil in the pan looked like that, you'd have a problem. My old VW race engines would do that in the catch can as well, between the months of October to February.
FYI, late model Hemi's have higher positive crankcase pressures than other pushrod V8's, and as such actually burn more oil than lets say a LS3 Chevy.
Was I supposed to list my mods here?
Old 12-17-2010, 06:32 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Just be glad that is not going back in your engine. Looks like the can is doing the job it was designed to do. It is condensation from the weather. You will see some of the same color in your oil pan the next morning if you leave your drained oil outside in a metal catch pan like I have done and that coloring is around the edges of the pan from the condensation. I think you are fine - just keep an eye on it and check your can each week. Wish I could put a catch can on my 2007.
Old 12-17-2010, 08:04 AM
iRESQu iRESQu is offline
Rep:2217
One more mod going to my list after seeing what DID NOT end up back in your engine!
Old 12-17-2010, 12:15 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
Where does this catch can get perchased from, and is it easy to mount. Thanks
Its not a mistake that mans best friend cannot talk.
