Old 12-03-2010, 06:33 PM
bfinley bfinley is offline
Vehicle: 1997 dodge ram 1500 sport 4x4
bfinley is on a distinguished road
Default valve covers?
I would like to make my engine bay alittle nicer to look at. I want a set of chrome or polished valve covers and im just goin to put a filter on the valve cover for the crank case. Where can i get some besides mopar? Does this 318 have the same valve cover bolt patern as the old ones. I dont mind taping the valve cover with a uni bit for the egr valve. Do i have to have year specific valve covers or just ones for a 318?
Old 12-04-2010, 01:13 AM
WORCSracing553's Avatar
WORCSracing553 WORCSracing553 is offline
Vehicle: 1999 Dodge ram
Color: red
WORCSracing553 is on a distinguished road
All the valve covers for the 318s are the same, as long as its new enough to be a magnum (1992 and up)....and if you want to find some nice chrome ones, id check edelbrock
Old 12-04-2010, 07:07 AM
why would magnum make a difference? Different valve cover bolt pattern? Older ones not tall enough for the rockers?
Old 12-04-2010, 08:59 AM
Rep:1909
I'm pretty sure they're all the same. BTW, that's the PCV system, not the EGR that goes into the valve cover.
Old 12-04-2010, 11:47 AM
Color: red
Im not 100% sure if the magnum has different valve covers, but the motor underwent some pretty big changes when they turned it into a magnum....i just know for a fact that 1992 and up are all the same
Old 12-09-2010, 12:02 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
Early "LA" engines have a few less valve cover bolts than the magnum motors do, and if you install a set of early covers on a magnum, you'll soon find out why they were changed, because they'll leak. It's not a matter of if, but when.
While no one makes a set of chrome covers for a magnum, a GOOD chromer could do them for. A decent chrome job will still cost you around 100 bucks but that's still a bit less than the cheapest polished aluminum covers
Old 12-10-2010, 10:14 PM
so basically i could buy the early 318 valve covers and drill for the magnum bolts
Old 12-11-2010, 12:28 AM
Trim Level: Fleet
Rep:47
I'm trying to visualise that and without the stamped in indents to clear the bolt heads I don't believe that would work. IMO it would look pretty hokey. Or very obvious.
Wth, try it anyway and if you ruin the valve covers, you'll learn a valuble lesson. If it works, we'll learn something.
Old 12-18-2010, 12:47 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Nope. Still won't work. The LA's used 3 bolts on both side of the valve covers (6) while the Magnum uses 5 bolts on each side (10).
