Old 12-04-2010, 07:21 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Default Who uses neutral?
Just curious, does anybody put their transmission in neutral in cold weather for their first start of the day? I had an equinox prior to my truck and I asked one day at the service counter if it was necessary to put it in neutral to help warm it up and I was told it was unnecessary since it was supposed to have a bypass system. Anyway, I put my truck in neutral for the first start of the day when it's cold.
Old 12-04-2010, 07:33 PM
Rep:2620
I think the only reason for Neutral in an automatic transmission is to have something in between Reverse & Drive, so that you can't just go directly from Forward to Reverse
Park is just Neutral with a parking pawl that keeps the transmission free wheeling
The parking pawl locks the transmission's output shaft to the transmission casing by engaging a pawl (a pin) that engages in a notched wheel on the shaft, stopping it (and thus the driven wheels) from rotating.
Old 12-04-2010, 07:55 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Neutral in cold weather is a bad idea. Doing so requires you to set the parking brake. Those have a bad habit of freezing in place due to residual moisture between the pads and disk or if you have shoe types, moisture between the shoe and drum. Plus it puts stress on the PB cable.
Brian:
Old 12-04-2010, 08:03 PM
Roswell Roswell is offline
Vehicle: 2010 Ram 2500
Roswell is on a distinguished road
Leave it in park.. As far as using the parking brake, go for it! I use mine 4-5 times a day, keeps it free and if you had a manual would have to use it!
Old 12-04-2010, 10:08 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I've seen plenty of fwd cars trying to drive off the mtn after a day of skiing and their back wheels are skidding b/c they set the parking brake while they where skiing.
Old 12-04-2010, 10:37 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
What is a parking brake??
Old 12-04-2010, 10:52 PM
Color: RootBeer
Rep:1287
aka emergency brake
Brian:
Old 12-05-2010, 04:35 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
would be a good idea a few years ago when transmissions didnt oil in park......545RFE pump runs in park and nuetral so no oiling issues hot or cold.....a good idea is to always allow some idle time before taking off......
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-05-2010, 09:57 AM
Rep:160
That's the response I was sorta looking for, good to know, thanks for that sprintertech.
