Tire Rotation - 2010 RAM - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-05-2010, 12:44 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
On rear wheel drive, or four wheel drive, driver rear goes to passenger front, passenger front goes to passenger rear, passenger rear goes to driver front, driver front goes to driver rear. You are basically crossing the rears and moving the fronts back. Front wheel drive cars are the exact opposite...cross the fronts to the back and move the backs straight forward.
The only time you only go front to back on the same side, is as stated above, when you have directional tread, which we do not. One thing about rotating tires...if a wear pattern is started, say from the front end out of alignment, the wear will continue even if it is moved to another location. It may slow down, but it will continue to wear the same as before you moved it.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 12-05-2010, 01:27 PM
JAMarkovich JAMarkovich is offline
JAMarkovich is on a distinguished road
Default Directional Tires or Not!
Thanks all for the info on tire rotation pattern. The last question I have is weather the Goodyear Wrangler HP P275-60R20 tires are directional. I could not find anything definitive even on the Goodyear web site or in any other on line references. I know that directional tires cannot be cross rotated.
Old 12-05-2010, 01:33 PM
Those tires aren't directional but I agree, front to back only with no crossing over.
Old 12-06-2010, 02:44 AM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
I believe there will be an arrow on the sidewall of directional tires to show the direction of rotation.
Old 12-06-2010, 08:56 AM
latitud's Avatar
Rep:78
Here you go, straight from the owner's manual. Of course it would be completely opposite of what I said, but here it is:
Old 12-06-2010, 02:44 PM
charlie3133's Avatar
charlie3133 charlie3133 is offline
Trim Level: SLT Plus
charlie3133 is on a distinguished road
So, how much is your dealership charging you for this? I am just heading in for an oil change and they said it's time to rotate
If you are what you eat then I am fast cheap and easy!
Old 12-08-2010, 04:46 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
I will agree with every one else, front to rear!
Working in a tire shop that is the only way we do our rotations, everyone seems to have a different opinion...mostly old timers with the whole cross pattern, many of the guys i work with argue that crossing is bad for radial tires as the belts wear in going one direction so with just crossing them over the tire is essentially rolling against itself and is more prone to seperation....with bias tires like back in the day crossing during rotation was fine!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 12-08-2010, 06:42 PM
Rep:2929
My dealership charges $19.95 USD to rotate the tires
Because the last time that they did a rotation, it shook the whole truck while highway driving, they could NOT fix it to my satisfaction.
I took it to a tire shop & had then switch them back & no more shaking. No charge, because i use them for 3 other vehicles
This time i told the dealer to pull off ALL the weights & balance them from scratch, they did, new weights were used & i saw that Every weight placement had moved at least 3 inches. They charged me for the weights $49.95 & $6.00 Labor.
There is no shake at all now & i can feel the road & the truck through the steering wheel again
Old 12-09-2010, 12:53 AM
09bighorn's Avatar
09bighorn 09bighorn is offline
Vehicle: 2009 Dodge Ram Quad Cab
Trim Level: SLT Bighorn
Rep:22
09bighorn is on a distinguished road
I rotate and balance the tires every oil change. I move the front tires straight back and cross rotate the rears. I notice that the rear tires have an odd feather pattern to them, but I think that has more to do with all these new black marks all over the nieghborhood.
tinted, remote start, slightly debadged, full swap to LED's in process, lockpick camera, truxedo deuce, Volant, linex ,more to come, just have to convince wife!
Old 12-09-2010, 02:42 AM
Rep:2929
Well, this is the last i will post to this thread
When steel belted radials first came out, the types of compound in the tire some how allowed the steel belts to form a shape pattern & if the tire was rotated to the opposite side of the vehicle, the steel belts would change the pattern & the steel belts would separate especially in the side walls.
todays rubber compounds have changed & supposedly the steel belts stay in place, but, tire shops still believe in doing rotations like they were taught, including my dealership & Discount Tire
Tire Rack apparently believes differently, they wrote this
http://www.tirerack.com/tires/tirete....jsp?techid=43
