New Noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 12-05-2010, 04:36 PM
von6324 von6324 is offline
Vehicle: 2005 Ram 1500 SLT qd cab 4x4
von6324 is on a distinguished road
Angry New Noise
Ok, it was only doing it when I started off going forward, but intermittently, and when got up to speed or after 1-5 seconds would stop. Sounds like a whining or groaning noise. Thought that it was the front left, but checked brakes, hub, bearings, lines, no joy. Checked diff and transfer case, fluids fine. Now it is also doing it when I go in reverse. Sounds like coming from under the driver seat. Has anyone had this problem or can any help me diagnose this so I can get it fixed. Suppose to go Virginia from Florida for Marine Schooling. Need to get it fixed soon.
Old 12-05-2010, 07:12 PM
Sorry...pretty hard to diagnose a noise from long distance. How many miles on your truck? It might be a bearing at the transmission. Does it do this only when it's cold?
Old 12-05-2010, 08:40 PM
mySRT8u's Avatar
mySRT8u mySRT8u is offline
Vehicle: 09 SRT8 Challenger
Rep:887
mySRT8u is a splendid one to beholdmySRT8u is a splendid one to beholdmySRT8u is a splendid one to beholdmySRT8u is a splendid one to beholdmySRT8u is a splendid one to beholdmySRT8u is a splendid one to beholdmySRT8u is a splendid one to behold
I was doing some research to see if anyone else was having familar problems as you and i came up with someone who took off there front diff brought it to a mechanic and ended up replacing the pinion bearings, fixing the problem.....Hope you figure it out, good luck!
Old 12-06-2010, 08:46 AM
I have 52,000 miles on the truck. It does not only do it when it is cold. It does it intermittently on acceleration and then stops.
