Old 12-05-2010, 09:10 PM
06ramhemizinn's Avatar
06ramhemizinn 06ramhemizinn is offline
Vehicle: 2006 Dodge Ram 4x4
06ramhemizinn is on a distinguished road
Question Other Rims for Dodge Ram ??
Hey guys, been doing some searching but can't seem to find anything on it,, What lug pattern is a stock '06 17" rim & what other vehicle rims will fit on these 3 rd gen Rams ???
2006 Dodge Ram 1500 Quad Cab 4x4
2" leveling kit ,just not install yet lol
Old 12-06-2010, 05:24 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
If i'm correct, from 94-up they're all 5x5.5 or 5x139.7 (mm). That's for all half-ton pickups. I'm not sure if any other vehicles have that same pattern, but yours would be 5x5.5
Old 12-06-2010, 08:03 AM
Yes, that ^^^^ is the spec.
Most wheel makers will have this bolt pattern available. The harder part is deciding how big to go and what offset you need so as not to rub based on your tire size selection.
Old 12-06-2010, 08:35 AM
Phreak Phreak is offline
Vehicle: 2010 Dodge Ram , 1983 Jeep CJ7
Trim Level: Crew Cab Sport
Rep:20
Phreak is on a distinguished road
Send a message via MSN to Phreak
Just a heads up.. these use the same Bolt pattern as the Jeep CJs
if your looking for rims at a bargin price.. head to a jeep forum and look in the for sale section.. Also i believe this pattern was use on Broncos of the early 80s
Old 12-06-2010, 08:43 AM
ok thanx guys !! ,, yaa was looking for an extra set of rims for the winter so i could take my chrome ones off ,,
- Phreak , if the ol CJ rims fit, wouldn't i have to get a set that were 17" & up, or will 15", 16" fit my Ram ???
Old 12-06-2010, 08:56 AM
Rep:20
15 might be tight.. depends on calipers if the rims will fit over them.. easy way to find out..
hit a scap yard and buy a beater rim for 10 bucks.. and mount it and test it out.. I have not pulled my off yet.. i have been meaning to.. since i have a CJ as well sitting on 36in TSL.. but the weather sucks up here in canada.. LOL
Old 12-06-2010, 09:02 AM
yaa , well on kijiji i can get a set of 15x10 5x5.5 fr a jeep for $60 !!! i would get them if i knew they fit,, Ya lol weather does suck here, rain this morn, than turned to snow, blowing and my only day off
Old 12-06-2010, 09:19 AM
Rep:20
a 10 in wide rim might be to wide depending the size of tire you plan on putting on it..
I would say make sure the tire is at lest 12.5 wide.. if you use a 10.5 wide tire on a rim thats 10 in wide.. it wont seed right and you run the risk popping a tire off the rim if you hit a curb.. .. I would say to be safe.. Look for a 17in rim..
Old 12-06-2010, 01:07 PM
Yaa Phreak , i wont bother with them rims,, i wanta find out if a 16" rim fits these newer Dodge rams , just want an ol steel set to put snow tires on ,,
