Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 02-26-2011, 12:31 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
The truck "should" regenerate on its on, if the trucks running hot enough (ie beat the hell out of it) it'll clear out the filter (passively) and if not the truck will use raw fuel to burn out the particulate(from what I've heard/noticed is that it can use several gallons of fuel) this is your active regeneration.
I say "should" because every once in a while they decide not to go into regeneration which puts the truck into limp mode so you can try lug it back to the dealer. Enough times make a dpf delete sound like a great idea
As the filter gets fuller it increases the back pressure in your exhaust. The backpressure shouldnt hurt anything much mechanicly just performance wise, when you think about how a turbo works you can only push as much air through it as you can push out of it.
In an effort to make these trucks run better everyone tries to lower there exhaust gas temperatures. Diesel particulate burns around 600 C (1112 F) by itself and somewhere around 350-450 C with fuel as a catalyst.
Old 03-10-2011, 02:03 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500; 2010 RAM 1500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
Originally Posted by pnsballard View Post
How do you "regenerate" the filter? I just picked up a 2011 2500 Laramie with the 6.7 last week and I already have the "Filter is 80% full" message at only 400 miles on the truck! I live on an Air Force Base and I have primarily been driving it on base at low speeds/stop-go traffic this week. Do I need to get her on the highway and open her up? My dealer also had to drive it up from another dealer that is 300 miles away. Could they have done something to it?
Highway speeds (70mph) and towing are the best solutions. If you could hook up a heavy trailer for just 30 minutes or so every week or two, you'd probably be okay. They need to be worked to stay clean and not trigger a regen.
2010 1500 Laramie Hemi: Magtec Rear Diff cover, 24" Magnaflow, Resonator delete, Line-X; Bilstein 2.75" kit;295/60-20 Wrangler Silent Armor Pro Grade; Lift Air Bag
2016 3500 Laramie MC: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 03-20-2011, 01:47 AM
Phillies3500 Phillies3500 is offline
Vehicle: 2006 Dodge Ram 3500
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Phillies3500 is on a distinguished road
ok for quick clarification. does the 5.9 have a dpf and if so do they sell a delete kit for it. this when this is removed you gain power and increase gas mileage. tuner is needed to turn check engine light off. correct me if i am wrong.
Old 03-20-2011, 01:58 AM
rsg1963's Avatar
Rep:48
Only the 6.7's have a dpf. All I have (5.9) is a Cat and it makes about zero difference in power if removed. I had my muffler guy remove it and I ran it for about a week. (No check engine light comes on) I noticed ever-so-slightly lower exhaust temps, but no noticeable diff in power or fuel economy. Apparently, the same can not be said for the dpf on the 6.7's.
Old 03-20-2011, 01:32 PM
thank you for clarification. pa laws are real strict about emissions so that isnt really an option here.
Old 03-20-2011, 02:59 PM
Color: Mineral Gray
Rep:177
There not all that bad in PA actually. I live in allegheny county which used to be the only county in PA that requires emission inspection. Diesel trucks are emmisions exempt (up untill 07 I think) How do you think all these guys with stacks get away with it haha
Old 04-01-2011, 08:51 AM
metterfalcon metterfalcon is offline
Vehicle: 2011 dodge ram
Trim Level: Big Horn 4x4
metterfalcon is on a distinguished road
i'm getting 17mpg on my 05 5.9L diesel now. I assume if i removed the DPF on my truck I would need to use a programer? From the above posts it was referring to a 6.7L?
Old 04-01-2011, 01:18 PM
Color: Mineral Gray
Rep:177
Only 6.7l have dpf systems on them
Old 04-01-2011, 08:34 PM
rsg1963's Avatar
Rep:48
You don't have a DPF. Only a cat and muffler (if it's stock).
