Old 06-28-2009, 06:43 PM
mcline1968 mcline1968 is offline
Vehicle: 2008 3500 DRW
Color: BLACK
mcline1968 is on a distinguished road
Smile AC blower problems
Hello all,
This is my first post on here and I am hoping that I find this forum to as helpful as the corvette and harley forums have been to me.
Here is my issue:
I have a 2004, 2500 4x4, 5.7
About a month ago i started having this problem that once in a while when i started the truck I would get no blowing from the AC. I could feel that there was very cold air trickling out of the duct but no blower. I would turn the truck off, then turn it back on and that would solve the problem.
Friday, it happened and the blower has not come back on since. at first i thought it was a panel switch issue but have since realized that the temp. switch and the blend switch are working.
So i feel it is now either the blower motor or the blower motor resistor.
How can i test the resistor and can i test the blower motor by simply connecting it straight to 12v and a ground?
Any suggestions would be reatly appreciated.
Old 07-05-2009, 02:44 PM
SpokaneDodge SpokaneDodge is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: SLT QC 4x4
Rep:17
SpokaneDodge is on a distinguished road
If it is the resistor the motor should still blow on the highest setting.
Old 07-05-2009, 03:22 PM
ljonesj ljonesj is offline
Vehicle: 2005 Dodge Ram Quad 1500
Rep:14
ljonesj is on a distinguished road
yeah it might still be the selector swithc in the dash or the motor itself
Old 07-07-2009, 09:42 PM
jamesb0 jamesb0 is offline
Vehicle: 2006 Ram 2500 Quad/ SB / 4x4
Color: Flame red
Rep:57
jamesb0 will become famous soon enough
If there was an issue with the motor you would have heard some noise most of the time ( DC motors are very reliable ) I would guess that the switch went or a lose wire fried. I would check to see if there's a circuit breaker first, they some times go, then work your way from there or the motor on back till you find power. I hate taking apart the dash. BE CAREFUL YOU CAN SET OFF THE AIRBAGS WHEN PROBING.
Old 12-22-2010, 11:34 AM
steelman512 steelman512 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 5.9L
Rep:27
steelman512 is on a distinguished road
I have been battling this same issue in my 02 Ram 1500. I have read somewhere that this issue lies within the steering column cover. I have yet to remove this and look under it, but may do it later today. The other issue with mine is that the blower stays on when I turn the truck off. When its on the lowest level, I ussually forget about it and come back to a dead battery the following day.
Good Luck!
2004 ram, ac blower, blower motor, blower resistor
