Old 12-06-2010, 05:08 PM
muskybait muskybait is offline
Vehicle: 2010 1500 Dodge Ram
Color: Two tone Black/Silver
muskybait is on a distinguished road
Default oil change warning revisited....
Hi Folks,
Had my oil changed at dealer a few weeks back and they forgot to reset oil change indicator on EVIC.
Thanks to this forum I had the procedure to reset when I needed it most.
I took a trip down to Gettysberg to visit friends over thx giving weekend. On my way back home (Ajax, Ontario)stopped for gas in NY. After pumping restarted truck and tried to shift into gear, no go...would not shift.
Couldn't understand why the shift problems then it dawned on me. The oil change indicator had not been reset (my fault, should have done right after oil change but procastinated..).....I assume the computer won't allow to shift if it deems oil change over due...I remembered the procedure ( pumping gas pedal 3 times to reset...)....started her up and shifted no problem.
If my assumpiton is correct, remember to rest the Oil change message on EVIC ASAP to prevent the shift override.
Again I assume the shift override related to the oil change indicator. Please someone correct me if I am wrong about this.
Musky...
Old 12-06-2010, 09:13 PM
Chubby Bruiser Chubby Bruiser is offline
Vehicle: 2010 Quad Cab
Color: Blue
Rep:84
Chubby Bruiser will become famous soon enough
I had no idea. I'm sure some experts will chime in here soon.
Westin Nerf Bars, Mopar Chrome Bug Deflector, Mopar Mud Flaps, Mopar Slush Mats, Chubby Antenna, K&N Drop in Air Filter, Bosch Wiper Blades, Weathertech Vent Visors, Mopar Trailer Brake Controller, Reese Tow Package with Anti Sway Bars, B Pillar Black Tape Removed, Mopar Chrome Gas Door, Mods to come - 14 inch Mufflex, CAI, Headers, Michelin Tires, Chrome Bed Rails.
Old 12-07-2010, 10:07 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
This is interesting..anxious to see what the experts say.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 12-07-2010, 10:31 AM
Rep:1845
No, it won't prevent your truck from going into gear. For some reason it defaulted to neutral from what I can figure. I'm thinking maybe it was a problem with fluid pressure in the transmission. There was a problem with this in the '07 model that was corrected with a PCM flash but there's nothing about it for a 2010. Get it to a dealer and let them see if there are any trans codes stored.
Old 12-07-2010, 11:00 AM
Hi Randy,
Thanks for input.
So the oil change indicator reset has nothing to do with shifting.
Strange how things were fine after I did the procdure to reset oil change warning.
The shifter would slide over but not down......post procedure, no problem at all and has not been an issue since.
Thanks for tip. I will call dealer and see what they have to say.
Musky...
Old 12-07-2010, 01:27 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Uh, did ya have your foot on brake?
Shifters in park are locked out w/o your foot on the brake,,,
Old 12-07-2010, 09:13 PM
Color: Blue
Rep:84
What would we do without Randy?
Old 12-10-2010, 11:18 PM
UH, yup but thanks...
Old 12-27-2010, 08:04 AM
WesGPS's Avatar
WesGPS WesGPS is offline
Vehicle: 2005 Dodge Ram HD 4x4 S. Box
Rep:68
WesGPS will become famous soon enough
Whoa-ho! This raises a question I have. One morning I had a downright wrestling match with the shifter because I couldn't get it out of park. I really don't remember if I had my foot on the brake or not. After I ran out of English and cooled off a little I did something (I know not what) and the thing went right in gear.
I think that the standard procedure of always putting my foot on the brake is so ingrained in me that it would be next to impossible for me to fail to overlook it.
That said, I did say "next to impossible" - which is another way of saying I am getting older and believe me, things do change . . . never mind all that . . . here's the bottom line question: is there anything in the computer system that can lock the thing in park?
Thanks, Wes
2005 Dodge Quad Cab Heavy Duty 4X4 5.7L Hemi.
Air Lift Remotely Controlled Air Bags.
Hellwig Rear Anti Sway Bar.
Viair Onboard Air System.
Old 12-27-2010, 09:27 AM
You need to definitely hit the brake pedal first before touching the shifter . If you apply pressure to the shifter first then hit the brake pedal it still won't unlock .
