Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-06-2010, 06:39 PM
jljohnson1170 jljohnson1170 is offline
Vehicle: 2000 ram 1500 slt quad
Color: gray
jljohnson1170 is on a distinguished road
Default Heater Core replacement question
I have a 2000 slt quad cab 2wd. As with most that I have seen my dash is cracked in about 30 places. I plan to replace it when I can but in the mean time I need to replace my heater core. My question... Can I replace the core from the top of the dash if I remove all the peices? Is this possible without taking out the whole dash?
Old 12-06-2010, 06:56 PM
B and B LANDSCAPES B and B LANDSCAPES is offline
Vehicle: 1999 Dodge Ram 2500
Trim Level: base
B and B LANDSCAPES is on a distinguished road
man i would love to know this one..... my dash is almost gone and it needs the heater core replaced..... would make life nice maybe
Old 12-07-2010, 01:37 AM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
If the dash is completely broken and exposed it may be possible, Maybe not. I haven't done the job but I have seen pictures and they always show the dash off. The heater core has some weirdly shaped lines which may need to be wiggled around to the right angle to get them in and out. More room would make this possible obviously. The core also has a cover that needs to be removed and I don't know if that is wedged under the cowl or not since I have always seen it removed. So it's a possible, Maybe!
www.beatcraigslist.com - for posting dangers & secrets
Old 12-15-2010, 11:21 AM
audiophile's Avatar
audiophile audiophile is offline
Vehicle: 1998 Dodge Ram 1500 Club Cab
Color: Blue
audiophile is on a distinguished road
I would say no. I replaced the heater core in my '98 last winter. Even if you could remove the dash pieces, (mine is cracked pretty bad also) there is the air bag pod to deal with. The way the water lines run through the dash would make it very difficult to remove it even if possible. The entire air box has to come out of the truck to remove the core. My dad and I did it in about 9 - 10 hours. We were able to move the dash and hang it from the passenger grip handle rather than remove it completely. I have pics and will post them. They are not the best but I took them with my cell phone.
Just FYI - you have to evacuate the a/c system and then have it recharged. If you don't the compressor will not come on and you will have no defrost.
They say hard work never killed anyone, but why chance it?
Old 01-06-2011, 11:25 AM
grungybob grungybob is offline
Vehicle: 1999 dodge ram 1500 4wd
Trim Level: sport
Color: red
grungybob is on a distinguished road
I just replaced the heater core on my 99 5.2 1500 4wd. I didnt take the steering column out just lowered down and the dash had to come out because the heater box had to come loose from the fire wall. But i did'nt take the heater box all the out like other instructions said and i was able to wiggle it out from the top with the heater box still mostly installed. I didnt have to discharge the a/c either, saved a lot
