Old 12-06-2010, 06:25 PM
08 SRT8 3560's Avatar
08 SRT8 3560 08 SRT8 3560 is offline
Vehicle: 2010 Super Challenger #10 011
Trim Level: Mr Norm's SC'd 6.1l
Rep:786
08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold08 SRT8 3560 is a splendid one to behold
Default SRT8 Shorty Header Question?
I am looking to find out if and which SRT8 Shorty Headers are compatible with the 2011 5.7 hemi. Don't tell Paris I am asking about this on her forum.
Mr Norms liquid cooled 2.8l Kenne Bell with 8lb pulley, Eibach coil over suspension, Hotchkis sway bars, Super Challenger Katzkin interior, Hurst short throw shifter. ARH longtube headers with high flow catted mid pipes, magnaflow cat-back exhaust. Black Viper style wheels with red raceline.
Old 12-06-2010, 06:36 PM
I push the skinny pedal
Rep:3277
Because it's not like Paris could find this thread on her own
Anyhow, is it for an SRT8, or a '11 5.7L. I'll assume it's for the new '11 5.7L, and as it stands, I can't find anything that'll fit the '11 yet. I don't believe they made any major changes from the '10, so you could try a set for that year, but none of the majors have a set of headers out yet.
Kurtis
Old 12-06-2010, 06:39 PM
Rep:786
I have come across a set of SRT8 stock headers that I plan on putting on her 2011 5.7. I am trying to find out if they will work or not. Thanks Cd.
Old 12-06-2010, 07:36 PM
Rep:3277
Ah, ok, I see what you're getting at now. Sorry, I guess I needed to read closer next time. I can't help ya though, my hemi build book is at home and I'm on the road, and I just can't remembr if the headers are compatible or not, I know most of the top end is with some porting.
Kurtis
Old 12-06-2010, 10:37 PM
I believe they will . The 6.1 manifolds are a hot comodity for the 5.7 guys . The 6.1's flow very well . I've been told they flow just as good as a set of long tube headers . Hopefully the outlet of the manifold is in the exact same place .
Old 12-06-2010, 10:38 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
i've recently read there is no gain for some aftermarket pipes from the stock str8's they did a good job on these. Just Sayin'
Old 12-06-2010, 10:41 PM
iRESQu iRESQu is offline
Rep:2217
Having found this thread......I asked my tech and he said the bolt pattern and exhaust and coolant passageways won't align. New holes would have to be drilled. Thanks though guys!
Old 12-07-2010, 02:13 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Interesting... from what I've read the D-shaped exhaust ports on the 09+ heads line up perfectly with a set of SRT8 headers. The new "Eagle" heads and intake are almost a direct copy of the 6.1 design. The earlier Hemi (02-08 gen III) wasn't an exact swap, but based on my research I do believe the 09 and up are.
As far as the SRT8 headers go, the ones from a car require a ton of modifications to work. Our frame rails and steering shaft seem to get in the way. From viewing pictures of each, the ones from an SRT8 Grand Cherokee are a bit different (they are longer and don't protrude as far from the side of the block) but I haven't been able to confirm if they would even work with minimal modification. I'm trying to get my hands on a complete exhaust from an SRT8 GC to try and confirm whether they would work, and also if their exhaust routing fits our trucks (looks to be a better flowing exhaust design all the way to the muffler).
Cheap easy power is always a win win for me.
Old 12-07-2010, 08:20 AM
Watch JBA for a set of headers coming for the 09 - 11 trucks coming soon!
I did a bit more digging but Daniel has the right of it.
Old 12-18-2010, 07:19 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
http://www.dougthorleyheaders.com/pr...productID/1037
2009+ headers. Have you guys seen this? saw it on the other....FM cant imagine these not performing as well as the SRT8 shortys or better. Direct bolt on, no thrown codes, and ceramic coated
They look nice as well.
