Another heat problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-06-2010, 08:20 PM
maddface maddface is offline
Vehicle: 1998 dodge ram 1500 slt
maddface is on a distinguished road
Default Another heat problem
98 ram 5.9 is blowing warm to cool. Top rad hose is hot, both core hoses are hot, bottom rad hose is cold. That mean tstat is stuck closed? Just replaced tstat with engine swap along with waterpump. Tried burping today. Added a few oz of fluid. Am i right about tstat stuck closed?
Oh, and also the seems like its running to cool. Temp gauge is at about 150 to 180 tops
Old 12-06-2010, 11:09 PM
B and B LANDSCAPES B and B LANDSCAPES is offline
Vehicle: 1999 Dodge Ram 2500
Trim Level: base
B and B LANDSCAPES is on a distinguished road
mine os currently doing the same exactly to the tee.... replaced motor did water pump and thermo, runs little on the cool side hoses about the same.... but i know i have heater core issues....
Old 12-07-2010, 07:13 PM
Dtimekw Dtimekw is offline
Vehicle: 2001 Ram
Color: Blue
Rep:23
Dtimekw is on a distinguished road
Sounds stuck closed to me. How long did you wait before you starting checking the hoses? Your temp guage should have gone way above normal (shut it off before it does). Once you see it go a little beyond it's normal reading, that's a sure indicator of a partial or total stuck t-stat.
01 Ram Sport, 5.9, Body/Suspension lift on 36's, 4wd
Old 12-07-2010, 07:30 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
With both core hoses being hot, its definitely not the heater core. Could be one of the doors is not working though and that's why you're not getting heat in the cab. Engine temp on the other hand should be HOT if the t-stat is stuck closed.
Brian:
