01 dodge ram sport headlights - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 12-06-2010, 11:01 PM
JBsport01 JBsport01 is offline
Vehicle: 2001 Dodge Ram Sport
JBsport01 is on a distinguished road
Default 01 dodge ram sport headlights
Hello all. Question for you. Adjust the headlights on these is not a problem. I have installed aftermarket lights but they are OEM. I tried adjusting them and the driver side is fine but the passenger side need to come toward the center of the road more but the adjustment screw is maxed out and cannot go further. Has anyone ever had this problem?
Old 12-06-2010, 11:16 PM
Can't say I've ever had a problem . Be careful though , it's only plastic . Hopefully you didn't crack anything . Make sure you stop by the newbie section and introduce yourself .
Old 12-07-2010, 12:00 AM
Luckily nothing is cracked....yet... Not sure what the deal is. I'm probably going to end up checking in with the place I got them from.
Old 12-07-2010, 11:18 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
You may need to add some washers or a spacer somewhere, I have used that on other lights
Old 12-07-2010, 10:56 PM
I was thinking about that but not sure where I would have to add them. It would have to be on the actual mounts that go to the frame of the truck. Putting them on the 3 bolts actually just ends up twisting it. I'll check into it!
