How well does it tow? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 12-07-2010, 12:30 AM
tcarlton0516 tcarlton0516 is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x4
Color: Blue Streak
tcarlton0516 is on a distinguished road
Default How well does it tow?
I am looking to replace a 2003 Ram with a 5.9 Cumins Diesel with 102K miles with a 2009 Ram with a 5.7 Hemi with 11K miles.
I pull a 27 foot travel trailer in Eastern Nebraska less than 2,000 miles a year average. The trailer weighs around 7,000 lbs., 500 lb tongue weight. I used to tow it with a 99 GMC Suburban with the 350 and it did pretty good. Pulled about 10K miles over 8 years until the rear end started causing problems and that's when I switched to the Diesel.
My question is will the 2009 Ram with a 5.7 Hemi do the job? Will I destroy the rear end?
Thanks for all the past and future help.
Troy
Old 12-07-2010, 12:52 PM
sobercrew's Avatar
sobercrew sobercrew is offline
Vehicle: 2003 dodge ram 1500 4x4
Color: silver/chrome
Rep:101
sobercrew will become famous soon enoughsobercrew will become famous soon enough
Send a message via Yahoo to sobercrew
the hemi will work might be a little under powered you cant beat a cummins for towing power
NEW SIG PIC YAY
Old 12-07-2010, 01:58 PM
Rogue's Avatar
Rogue Rogue is offline
Vehicle: 2009 Ram 1500 Crew Cab 4x4
Trim Level: TRX, 25T pkg w 5.7 L
Rep:22
Rogue is on a distinguished road
Send a message via ICQ to Rogue
You can see what truck I have, I tow a 20 ft boat without any problems. I also tow a car trailer, same--no problem. Recently I had a job where I had to haul a Genie Man lift around and that weighed about 7000 lbs, I had no problems. Thats a big load but the truck was great, punch the tow button when driving short distances and when on the highway take the tow off--no problem handling or passing or braking. It's a great truck.
Enjoy your new truck, they have impressed a lot of us.
Enjoy the Ride!
Old 12-08-2010, 07:30 PM
dafoot dafoot is offline
Vehicle: 2017 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
If the Ram has 3:92 gears, go for the switch. If it has 3:55s RUN. I pull 4k with 3:55 gears. I am really unhappy how my Ram pulls.
DAFOOT
Old 12-08-2010, 09:18 PM
SoDakMac's Avatar
SoDakMac SoDakMac is offline
Vehicle: 2014 Ram 1500 Limited
Trim Level: Longhorn Limited
Color: Deep Cherry Red Crystal
SoDakMac is on a distinguished road
Well you can bet it will not tow like the diesel. I purchased mine off the lot when the fire sale was on otherwise I would have looked for a truck with lower gears. The 3.55 gear ratio is OK for my use, which is towing a 20 boat but not sure how well it will tow a heaver load. My previous trucks were F250diesels, which were towing machines but I did not really need that much truck any longer. I really like the Ram with the Hemi no complaints here.
Old 12-08-2010, 10:09 PM
Bearwhiz's Avatar
Bearwhiz Bearwhiz is offline
Vehicle: 09 Ram 5.7 Hemi 4x4, 3.55
Trim Level: SLT Lone Star,
Color: Lt. Graystone Prl
Rep:40
Bearwhiz is on a distinguished road
I traded in my Ram 2500 5.9 diesel for the 2009 Hemi. Its a nice truck but I want my diesel back. Everyday use you will love the hemi. As soon as you hook up your trailer you will find out that you can kick yourself in the butt.
It's my job to protect your ass... not kiss it!
Old 12-08-2010, 11:15 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I swapped my 3.55s out to 4.10s and a True Trac. Haven't done any towing yet but daily driving is a little more fun.
Old 12-10-2010, 11:43 PM
PITA PITA is offline
Vehicle: 2009 Dodge Ram Quad Cab 4x4
Color: Two tone tan
PITA is on a distinguished road
What do you experience?
My Hemi with a 3:55 and 20's pulls my 5300 pound 27 footer EASY! Plus I usually have a 800 pound Harley in the side garage with about 800 pnds. in tongue weight (it's a toy hauler travel trailer). With a proper hitch and stabilizer, it's really effortless.
Compared to your '99 Sub, you won't believe the diff!
For most of the driving I do which does not involve towing, the Hemi with the 3:55 makes most sense - engine is worthy of a sportscar with decent economy.
Road King Classic, VFR1200, Fireblade, DRZ400SM
Ram Laramie Quad 4x4, RX8, 128i Cab
Old 12-11-2010, 12:06 AM
CHVYKLR's Avatar
Rep:252
I pulled a double axle car hauler from FL to VA with my 3.55s and averaged 13-14 mpgs. It was about 6000 lbs and pulled fine on the hwy.
I went with the 4.10s b/c I wanted a little get-up.
Old 12-11-2010, 02:15 AM
Rep:2962
towing 7,000 pounds, get the 3.92 rear end, mileage between 3.55 & 3.92 is not much difference running without towing is close to the same, but, the 3.55 can't pull a hill like the 3.92 when weight is involved
