Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Place your Ad Here!
Old 12-11-2010, 12:28 PM
dafoot dafoot is online now
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
Originally Posted by PITA View Post
What do you experience?
My Hemi with a 3:55 and 20's pulls my 5300 pound 27 footer EASY! Plus I usually have a 800 pound Harley in the side garage with about 800 pnds. in tongue weight (it's a toy hauler travel trailer). With a proper hitch and stabilizer, it's really effortless.
Compared to your '99 Sub, you won't believe the diff!
For most of the driving I do which does not involve towing, the Hemi with the 3:55 makes most sense - engine is worthy of a sportscar with decent economy.
Anytime you gave tuff towing conditions like hills or wind. The Ram is going out of lockup often. Even not pulling anything, same conditions, Ram goes out of lockup, but not as often. Because of this, when pulling my boat, The Ram gets worse miledge than the Tundra. Thats why I have stated on other post, all 4x4s should come standard with 3.92s. I have asked on this site, if the Ram can hold up long term to the constant unlocking the the torque converter. I did not get any answers.
DAFOOT
Old 12-12-2010, 01:45 PM
Allstate48 Allstate48 is offline
Vehicle: 2010 Dodge Ram-1976 D200
Trim Level: SLT- Orange&rust
Color: Cool Vanilla
Rep:53
Allstate48 will become famous soon enough
We traded an 08 Hemi, with 3:92, for a 010 Hemi with 3:55. I love the 10, ride, POWER, comfort, but I hate the gears. If you live in Kansas, no hills, you'd be fine. Southern Iowa, has hills. Even out of overdrive, when our boat is hooked on, it shifts all the time. Good luck Doug
Old 12-12-2010, 02:36 PM
Zeus Zeus is offline
Vehicle: 2011 Ram 2500
Color: Rugged Brown
Rep:27
Zeus is on a distinguished road
I have a 09 with the 3.55's plus a six inch lift and 35's. I pull a 24' cuddy cabin boat. I will agree the gears arent the best for towing. I just put it in auto-stick and dont let it out of 4th. Sucks for gas but pulls like a dream. Although I did used to pull this boat with a 99 Jepp Grand Cherokee with the V8 so I am known for overloading I guess
Old 12-15-2010, 12:40 PM
Pecos Bill Pecos Bill is offline
Pecos Bill is on a distinguished road
I have an 04 Hemi 4x4 3.92's I pull a 28' trailer in overdrive. NP about 4500 lbs but when I hook up my 5th wheel there is a big difference. 6800 lbs dry (probably over 75oo lbs loaded) 1200 lb tongue weight. 160 lb genny in the bed. Pulled it to Colorado from Michigan and back. 10MPG in Michigan but once I hit Iowa and the corn juice in the gas, the mileage went south. Didn't do the hills very well with all the downshifting etc. Truck has plenty of power but the 04 tranny has trouble getting into the gear I want. So, pulling a hill in 3rd, drops to 3000 rpm then downshifts to hi 2nd. Then to 1st and 5200 rpms. Gotta slow down and loose your momentum.
If you don't go long distance, and don't drive in mountains you should be fine.
Old 12-16-2010, 12:21 AM
tcarlton0516 tcarlton0516 is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x4
Color: Blue Streak
tcarlton0516 is on a distinguished road
Quick update. I purchased an 2011 Ram QC 4x4 with the 5.7 Hemi 3.55 gears. Really happy with the truck, gets around on slick roads very well even without the 4wd turned on. Oh, by the way I kept the diesel for towing the camper ; ) Thanks for all the advice. I may try the Hemi pulling the camper on a couple of our short trips this year just to see how it does. If I don't like it then I only have to drive 25 miles home to get the diesel to pull the camper home!
Old 12-16-2010, 12:50 AM
Run home for the diesel, LOL I love it!! My Colorado trip was just over 2900 miles (up to 9000 feet) and we went to Mt. Rushmore on the way home. Didn't have to run get anything except trailer tires. LOL (Not funny at the time but that is another story) My 1/2 ton Ram is a winner. The 2011 has more Horse Power than mine so you will probably be fine with the 3:55's pulling your trailer.
Old 12-16-2010, 02:28 PM
PITA PITA is offline
Vehicle: 2009 Dodge Ram Quad Cab 4x4
Color: Two tone tan
PITA is on a distinguished road
mileage between 3.55 & 3.92 is not much difference running without towing is close to the same
Don't think you can say that, it defies logic that it would be close to the same. Unless your definition of "close" isn't really close.
Every ram I saw supplied as test units to the media had a 3:55 for a reason - better fuel economy.
Road King Classic, VFR1200, Fireblade, DRZ400SM
Ram Laramie Quad 4x4, RX8, 128i Cab
Old 12-16-2010, 05:12 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
The Hemi (and really any V-8 gas engine) simply does not have the torque of a Cummins or other diesels (probably around 400 lbs per foot for the Hemi and about 550+ lbs per foot the Cummins - not a small difference by any means). I forgot what the 2009 Hemi has for towing cabilities but if you are looking at the 2500, I am quite sure it would have the needed specs for your travel trailer (check the specs of your potential new truck to be sure). Since I have not read all the other threads closley, at the danger of being repetitive, the other big difference between a diesel and gas when it comes to medium to heavy towing is the MPG. The Hemi will gulp fuel going up hills and under other more strenuous situations at a much faster rate than the diesel (not sure what the average MPG is for the '03 Cummins).
I think you are fine with either truck although I personnaly prefer the diesels for a variety of reasons.
Good luck.
Old 12-19-2010, 05:15 PM
eltoro2's Avatar
eltoro2 eltoro2 is offline
Vehicle: 2oo9 standard cab 4~4 1500 ram
Trim Level: plain
Color: pearl black
eltoro2 is on a distinguished road
a 5.7 hemmi toes great but guzzels gas . stay with A DIESEL.
Old 12-19-2010, 11:41 PM
RAM2009's Avatar
RAM2009 RAM2009 is offline
Vehicle: 2009RAM 1500 4X4 Hemi 3:92 DIF
Trim Level: Big Horn Laramie
Color: Inferno Red (Crystal Pearl)
Rep:72
RAM2009 will become famous soon enough
My 09 with 3.92 gears seems to impress me everytime I test it. I have hauled a covered car hauler with a car in it and it pulled REAL strong and many other lighter loads! I feel that the truck would tow anything I would need it to power wise but if I was to throw weight behind it on a regular basis, I would get some airbags to help it in the suspension department......
