Old 12-22-2010, 05:49 PM
tcarlton0516 tcarlton0516 is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x4
Color: Blue Streak
tcarlton0516 is on a distinguished road
Just to be clear I have both! Lol I might sell the camper and diesel as a package and buy a smaller lighter camper that the Hemi could pull, but that's a couple of years off.
Old 12-25-2010, 12:39 AM
shocker420's Avatar
shocker420 shocker420 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Dark Grey Metallic
shocker420 is on a distinguished road
I pull a 5500lb camper with a 660 raptor in the box it does a great job, truck has 3.92 gears
Old 12-25-2010, 05:56 PM
LetsGoOilers LetsGoOilers is offline
LetsGoOilers is on a distinguished road
I have an 09 with the 3.92 gears and I pull a 7200 lb 33 foot bumper pull with about a 750 lb quad in the box. It pulls nice but I would recommend a set of airbags or a timbren kit. I am going to install the timbren kit in the spring as the truck sags pretty bad with all the weight.
Old 12-25-2010, 08:01 PM
flacrkr1ton's Avatar
flacrkr1ton flacrkr1ton is offline
Vehicle: 1998 ram 3500 drw
Trim Level: SPORT
Color: RED
flacrkr1ton is on a distinguished road
I like my cummins, my last one 1995 had 3:5?s pulled great but limited to 65 mph loaded at 23,500# gross,my current ram 1998- -12v has 4:11s no limit on speed with a 35 foot fifthwheel camper at around 14,000#, i ran at both weights with overdrive on [not recomended by the owners manual] but i did it with no problems.
Red neck engineerin beat to fit paint to match
Old 01-24-2011, 08:41 PM
ctm533 ctm533 is offline
Vehicle: 2015 Ram 1500 Crew Cab
Trim Level: Outdoorsman
Color: Black Forest Green Pearlcoat
ctm533 is on a distinguished road
Originally Posted by gabrieldy View Post
I swapped my 3.55s out to 4.10s and a True Trac. Haven't done any towing yet but daily driving is a little more fun.
What does it take to swap them out? Time, effort, $$$?
Thanks!
Old 01-24-2011, 09:42 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I didn't do this install myself but labor is about half a day. I ordered the parts then found an installer and the total was around $1100-1200 IIRC. The most expensive part was the true trac...$500 or so. You could save a few dollars if you have a different diff in mind. I'm going off memory but my cost estimates should be pretty close.
there is a lot to the install and you want the backlask perfect so the gears don't "whine" when you drive. you can prob Google the install procedures but if you haven't done it before I'd suggest getting someone who has to at least "help" you.
Old 04-05-2011, 11:19 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Is your truck 4x4? If so, that is a great price to get gears for both axles, a tru-trac and installation for $1200. What kind of gears did you use?
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 04-06-2011, 12:43 AM
CHVYKLR's Avatar
Rep:252
I'm 2wd and used G2 gears. The truetrac is what drove the price up the most but worth every penny. I then capped it all off with a mag hytec diff cover...it holds just over 4 qts now!
